Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
The Bike - C10
(Moderator:
George R. Young
OEM Bags - What Plastic?
« previous
next »
Print
Go Down
Author
Topic: OEM Bags - What Plastic? (Read 3452 times)
mcman56
Jr. Member
on:
February 07, 2014, 08:23:05 AM »
Does anyone know what plastic the OEM saddle bags are made from?
Logged
Bergmen
Guest
Re: OEM Bags - What Plastic?
Reply #1 on:
February 07, 2014, 09:49:25 AM »
I believe they are polypropylene.
Dan
Logged
mcman56
Jr. Member
Reply #2 on:
February 07, 2014, 07:36:39 PM »
The plastic seems very hard not like dirt bike pp. Could it be glass filled or some thing else?
Logged
Summit670
Full Member
Country:
Reply #3 on:
February 08, 2014, 09:12:18 AM »
I repaired a crack where the bag hooks to the antler. Can't remember but thinking it was a few inches long.
I did not see any evidence of fiber content in the plastic.
I took a piece of paper and cut a pattern to match the area I wanted to repair.
Transferred that pattern to aluminum sheet and cut out a piece to match.
Did the same pattern making/aluminum cutting for outside of bag (it was a simpler shape)
I formed the aluminum to match the contours on the inside and I believe the outside pieces were just flat.
I drilled rivet holes in a number of spots.
I put black rtv on the backside of the alum pieces to seal out any water entry and riveted into place using aluminum rivets. Has held fine since the 90's.
I also painted the outside of the alum flat black. Don't recall if I did before or after install but can barely see it when bags are mounted.
Logged
Arctic Cat M8 163 rules
Sleds, Dirt Bikes, ATV's, Street Bikes, Mountain Bikes. Heck, I guess if it has handlebars I'll give it a try.
connie_rider
Sr. Member
Reply #4 on:
February 08, 2014, 11:13:41 AM »
Best way to repair bags is plastic weld. Few if any glues are strong enough.
If cracked, (after plastic weld), install a piece of metal inside the bag and attach it.
Seal from inside with whatever.
Logged
mcman56
Jr. Member
Reply #5 on:
February 08, 2014, 02:57:33 PM »
This is kind of funny. I went to put the one good bag on and the bag that is cracked is not from the side the bike fell on. It is from the non fall side. It must have been cracked the 4 or 5 years I have owned the bike. The cracks are small and can only be seen when flexing the mounting area out.
Logged
Bergmen
Guest
Reply #6 on:
February 08, 2014, 08:13:50 PM »
Quote from: mcman56 on February 07, 2014, 07:36:39 PM
It's not reinforced but there are dozens of grades of polypropylene.
Dan
Logged
Summit670
Full Member
Country:
Reply #7 on:
February 08, 2014, 08:27:42 PM »
I went to a guy who welds plastic bumpers. He was referred by a buddy of mine who was an insurance adjuster, said the guy does good work. He welded my bag and it looked good. I noticed after a month the weld wasn't holding so I was picking at it and the whole weld came off and the plastic looked the same other than where he had melted it a little with the welder.
Logged
connie_rider
Sr. Member
Reply #8 on:
February 10, 2014, 03:38:03 PM »
Plastic welding is not always a particularly deep weld...
Can/will break again if in a bad location. On the bags, reinforcement is needed.
Ted
Logged
elvin315
Global Moderator
Full Member
Country:
Reply #9 on:
February 11, 2014, 01:07:01 AM »
Read the Bodywork FAQ for info and helpful links:
http://www.zggtr.org/index.php?topic=659.0
Logged
Print
Go Up
« previous
next »
The Bike - C10
(Moderator:
George R. Young
