Author Topic: Ignition will not open?  (Read 18638 times)
Re: Ignition will not open?
« Reply #40 on: February 22, 2014, 06:59:09 AM »
Wasn't lucky for either the rabbit or the Elk, was it?  Therefore, I'm 'sticking' with what 'works' for me.   :)
Well, without knowing the circumstances that led up to the rabbit and/or the elk loosing said foot, we have no way of knowing if it was lucky or not.
Offline JhVenezuela
  • Country: ve
« Reply #41 on: February 23, 2014, 06:57:39 PM »
Let me show for first time in this forum the "Steering Lock Error"
After i reset the display the error has not showed again.
« Reply #42 on: February 24, 2014, 07:57:47 AM »
Interesting- I do not think we have seen that one before. It is service code (error number) 68 and the explanation is somewhat generic- there is some contact difficulty with the ignition switch housing KiPass unit. ?? It has absolutely nothing to do with the steering lock as we think of it (where you turn the bars fully to the left and turn the key fully counter clockwise) but the electronics locking aspects of the ignition switch.
Seeing as you opened the gray connector, make absolutely sure it is fully seated and connected. Sometimes it take a bit of force to fully close that connector as there are seals inside it that make it waterproof.
If it goes away and stays away, I would ignore it and chalk it up to an oddity of the system resetting after being disconnected from the main battery.
