Author Topic: Ignition will not open?  (Read 16884 times)
Offline SuazoC14
« on: February 01, 2014, 10:40:28 PM »
I use my bike tonight came home and park it, few hours later i try to start it and the ignition will not open.  Then i found this, easy fix.. just watch this in youtube.. i am sure most of you have seen this issue but just incase here it is, by removing the top portion of the selenoid everything works normal, the only difference is no need to push down, only to lock and ulock!!
Kipass failure Kawasaki Concours 14
« Last Edit: February 02, 2014, 02:19:59 AM by SuazoC14 »
Offline TallyRex
Re: Ignition will not open?
« Reply #1 on: February 02, 2014, 03:27:57 AM »
Sometimes I will have to press down 3 or 4 times before the ignition will unlock, so I would like a permanent fix, but the video only showed me the tap method works.  Did I miss something?  Actually I would like to get rid of the entire KPASS system and just use the key as every other bike does.  Is there some easy, inexpensive way to do that?
Offline Rembrant
« Reply #2 on: February 02, 2014, 05:56:16 AM »
I use my bike tonight came home and park it, few hours later i try to start it and the ignition will not open.  Then i found this, easy fix.. just watch this in youtube.. i am sure most of you have seen this issue but just incase here it is, by removing the top portion of the selenoid everything works normal, the only difference is no need to push down, only to lock and unlock!!
Holy crap....dude, I hope you didn't remove the entire front end of your bike to access the ignition?...lol.
You found A spring in the ignition, but you didn't find the right spring.
The sticking spring/button in question is just under the key, at approx. 8 o'clock. The button under there isn't really weather proof, and dirt/dust/debris gets in it, and the button sticks. All you have to do is pull the top triple clamp off, and remove the ignition housing. Clean the button and surrounding area with electrical cleaner, and then lubricate it. You'll never have a problem with it again. Kawasaki installed a heavier spring under this button in 2009, so that's why it was only really an issue with the 2008 models.
I took it apart on my 08 C14, cleaned & lubricated it, and it never acted up again.
There's no need to disable the KiPass system and key lock, or even to go near that solenoid...just clean the sticky button and spring, and it'll work as good as new.
You can put the front of your bike back on now. :thumbs: :thumbs:
« Reply #3 on: February 02, 2014, 06:23:16 AM »
Not that we're aware of...
I think that the video is good as far as showing the switch housing.  Everything we've seen so far echoes what Rembrandt said.  I've never heard of an issue with that side of the housing.  Brian is going to have to chime in here as he's fairly knowledgeable on that subject.
Offline Rembrant
« Reply #4 on: February 02, 2014, 06:44:30 AM »
Yeah, there's nothing wrong with the solenoid. The problem that suazoC14 is having here...with the solenoid sticking, is because the button under the key is dirty and is sticking (because the spring is weak). It gets a little dirt in it, and the spring isn't strong enough to overcome the sticky part. Once it is cleaned, and lubed, it works like new again. I believe Kawasaki changed this spring sometime in 2009 to a heavier duty version, and it will overcome any dirt or debris that gets in the button.
I know dealers were replacing this spring in the 2008 models with the newer heavier version....for a while...not sure if they still are or not. Like I said, if you clean it up and lubricate it, it will work just fine, even with the original 'weak' spring.
Offline SuazoC14
« Reply #5 on: February 02, 2014, 07:12:28 AM »
My bike is a 2009 but for now i have removed the top portion if the selenoid to get me by, will follow up on the ignition housing next time.. thanks guy.
Offline Rembrant
« Reply #6 on: February 02, 2014, 07:20:36 AM »
All you have to do is clean the button and spring, and you should be fine after that;). You can re-install the top portion of the solenoid this way.
Offline SuazoC14
« Reply #7 on: February 02, 2014, 07:25:54 AM »
I kind of like not needing to push in... just turn the knob no real need for the push in activation, they only did that so ur bike will not turn over without the fob, but even without the fob the bike will never turn on..
Offline st2sam
« Reply #8 on: February 02, 2014, 12:15:54 PM »
Spray a small amount of WD-40 on the Key once a month and you shouldn't have any more trouble. (it's what I do)
I always turn my key to the right so I can remove it. I always use that key to unlock the gas cap and bags, not the key in the fob.
My bike is a 2009 with over 50,000mi. on it, the switch still works like new.
2009 Kawasaki C14
1993 Ducati 907ie (for sale)
« Reply #9 on: February 02, 2014, 12:26:27 PM »
I've never been a fan of oily lubes for locks as they tend to hold dirt. I use a graphite based lock lube.
Offline Rembrant
« Reply #10 on: February 02, 2014, 12:40:36 PM »
Spraying oil on the key won't have any effect on the sticky button issue that the original poster is having.
« Reply #11 on: February 02, 2014, 02:14:45 PM »
I believe the heavier springs appeared in 2011 and are being retrofitted to earlier models by dealers, at least in cases where the bikes are under warranty, and I believe even at least some that are not.
The heavier springs reduce but have not eliminated the switch sticking 'on' problem; I know of a '13 that got stuck on a trip and the new, heavier spring was replaced with the new, heavier spring :-)
Changing the spring is quite easy; getting to where the spring can be changed is not and requires a couple of security bolts be drilled out from underneath the ignition switch assembly so it can be disassembled. I can be done by the shade tree mechanic but it is a fairly ugly job best left to a competent dealer if they will take care of it.
Sooner or alter, and it looks like it will be later, Kawasaki should re-fit this system with a positive- return system where the key will be rigidly attached (easy boys!) to the activation switch. This would not only show that the switch had stuck in the down or 'ON' position but would allow the operator to manually lift the key and switch with absolutely certainly.
<snip>
Offline viper
« Reply #12 on: February 02, 2014, 03:19:50 PM »
ive just tried the disconect the grey plug method in case i ever need this. With my Fob in range ive unplugged the grey box, nothing happens there is no click. to turn the key I still have to push down for the click
will this method allow the bike to be started without the fob?
« Reply #13 on: February 02, 2014, 03:30:04 PM »
Yep, that is one method to get around a stuck switch. Clunky and cumbersome though- there are other, 'slicker' methods but I do not want to belabor that point.
No, you cannot start a C-14 without a valid, working fob that the bike has been coded to recognize. Any bypass methods we are talking about simply bypass the activation switch, not KiPass itself. KiPass cannot be bypassed using any feasible, practical method.
Offline viper
« Reply #14 on: February 02, 2014, 03:58:09 PM »
When I unplug/plug  the grey block it does not allow me to turn the key, what am i doing wrong? can you explain the procedure to me, just want to know this bypass in case i ever get stuck
« Reply #15 on: February 02, 2014, 04:38:26 PM »
If plugging the gray connector back in does not illuminate the dash screen, make an audible 'click' or anything else, then you do not have the 'stuck activation switch' problem.
That is all there is to it- just unplug the connector and re-plug it and if the activation switch is stuck, the bike will 'turn on', the dash will light and the ignition switch will unlock for (I think) 5 seconds. Then everything will lock up again.
I also sell a commercial product to do this same thing easier and more gracefully and you can take a look at: http://www.zggtr.org/index.php?topic=6976.msg82841#msg82841   But again, if the gray connector being re-connected does NOT cause the dash to light up then you do not have the stuck activation switch and do not need and cannot use any bypass method, including mine.
« Reply #16 on: February 02, 2014, 05:36:35 PM »
Thank goodness.  We don't want such an expensive bike to be easy to steal!
Offline viper
« Reply #17 on: February 03, 2014, 02:29:12 AM »
thanks BDF , thats very helpful.
While we are on the subject of bypass, a forum member that we have all foloowd for a number of years called MGvalerio claims he can defeat the kipass in 15 seconds. Ive read the thread on here where he made the claim and saw all your responses. Initially I dismissed it but coupled with the fact that he is somewhat of an engineering genius, have you seen the modifications he has come up with. He is adamant that his bypass is there . Now someone else on the Net is saying the same. Im inclinded to believe him now.
back in the uk several years ago we had a GM car that could be started by taking out the hazard light switch and plugging it in upside down,the ignition all became active!!
you just never know!
Offline JhVenezuela
  • Country: ve
« Reply #18 on: February 18, 2014, 09:27:51 PM »
Yesterday after 6 year with my connie I had the same problem. I had read about that.
Ok. I did the procedure with the gray connector but nothing happened.
The battery is Ok
All the fuses are Ok.
Any idea ?
I have plans for this weekend  :'(
« Reply #19 on: February 19, 2014, 09:40:03 AM »
I would suspect a fob communication issue: try removing the key from the back of the fob, holding the fob against the boss on the front of the ignition switch housing and then press the key down. If that doesn't work, hold the fob in the same place and pull the fuse out of the by- pass harness and put it back in. What you may have is two different problems here: a dead fob battery AND a stuck activation switch. Unlikely to be sure but it could happen. But first, I am betting on the bike not sensing the fob due to a dead battery, the fob got damaged, or anything similar. The really easy way is again, use the RFID method in the owner's manual that I have outlined above: hold the fob against that boss and press the key down.
Also, try the other fob just in the odd and unlikely event that the main or primary fob failed for some reason (although both the RF and RFID portions failing at the same time, without tremendous physical damage having been done would be amazing).
Also check the battery cables and make sure you are getting power to any one of the three fuse blocks. If the battery is charged but the main fuse has opened, nothing on the bike will work. If you have a voltmeter or a small test- lamp, see if there is voltage inside any fuse box on the incoming side. I wrote an article quite a while ago on how to do this with an LED but I don't know if you are a COG member and got the Concourier.
One of those things should work. If not, more in- depth diagnostics will be needed.
Best of luck.
The battery is Ok
Any idea ?
