Author Topic: C-14 Shock Setting for C-10  (Read 13068 times)
Offline diego092409
  • Have to keep it running w as much as I have spent
« on: January 13, 2014, 04:03:34 AM »
I just completed installing a C-14 shock install on my 1997 C-10.  It was very straightforward and practically a straight bolt-up after scouring this and COG's forums.  My questions is, what have other people that have installed this mod on their C-10 used for setting on the preload and rebound damping?  I found the old shock to bottom out more often than what was comfortable with my girlfriend and I driving two up with the old shock's damping pulled out the whole way.  I found setting based on C-14 riders but I don't know if the C-10 will be significantly different or not.
1997 Concours - ZG1400 Rear Shock, Cee Bailey Screen w/ MRA Spoiler, Phone Charger Socket, Ram X-Mount, Shad 48 Liter Top mount, Tokico 4 pot front brakes w/ SV Racing Bracket, Intiminators, Baldwin Cycles Seat, Throttle Lock and Murph's highway pegs
1982 GPZ 1100 w/ 2006 GSXR Forks and swingarm
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: C-14 Shock Setting for C-10
« Reply #1 on: January 22, 2014, 06:16:32 AM »
keep in mind that the c-14 shock is softer on the c-10 due to difference in the rocker geometry. That changes the settings. I found that rebound was best at 1/2 turn from all the way out. HTH, Steve
