ewwwwwwwwwwwww pushing pins thru wires?
start at a simple spot, pull the tank, and check the blk/yel ground wire that attaches to the bolt on the left side coil mtg point...pull the bolt, check the terminal and the wire, if it's fatigued and broken, replace the ring lug...clean the surfaces and replace.
carry on....
oh, Tony's stick coils are super nice also....(you're welcome T...)
