Author Topic: part number for metal plate  (Read 3239 times)
Offline 12menzer
« on: December 29, 2013, 08:06:31 PM »
I need to order a new battery access plate.  Does anyone know the part number?. I have a 09.
thanks
Offline Warbird
Re: part number for metal plate
« Reply #1 on: December 29, 2013, 08:58:17 PM »
36001-0105-18R.......... :)
I'd Rather Be Roadracing.
« Reply #2 on: December 29, 2013, 09:01:26 PM »
It appears to be 36001-0105-18R
http://www.ronayers.com/Frame-Fittings-C419630.aspx
36001-0105-18R   COVER-SIDE,BATTERY,RH    $78.81
also http://www.2wheelpros.com/oem-parts/kawasaki-cover-side-battery-rh-black-36001-0105-18r-part.html
OOPs, I'm second again.
Offline jtk1531
  • Country: my
« Reply #3 on: December 29, 2013, 10:12:35 PM »
you might want to keep www.kawasaki.com bookmarked for parts number search.
www.kawasaki.com have detailed parts diagram/listing, with up-to-date year models.
i check there to see the latest parts number. sometimes i use it to get an idea what are the latest "bug fixes" for any particular area of the bike that i might be working on in future. new/replacement parts are indicated with a red mark on the parts listing.
navigation-wise, on the left side of the website, go to "owner info" --> "parts diagram".
Offline 12menzer
« Reply #4 on: December 30, 2013, 10:18:59 AM »
Thanks for your help.  I thought that was the correct part and I just wanted confirmation that I read the diagram correctly.
« Reply #5 on: December 30, 2013, 10:55:42 AM »
I have to ask....what happened to the original?
Offline 12menzer
« Reply #6 on: December 30, 2013, 04:35:56 PM »
I scratched up the original when I was replacing my battery.  The cover was on extremely tight and the Allen wrench slipped when I was removing it.  PITA.... >:(
« Reply #7 on: December 30, 2013, 08:31:32 PM »
 :doh:
« Reply #8 on: December 30, 2013, 09:37:49 PM »
fortunately it was that little part and not the tank or fairing  :D
Offline 12menzer
« Reply #9 on: January 01, 2014, 10:50:12 AM »
Yes, I am glad it was minor damage.  I need to buy some T handle Allen wrenches from Sears.
When I installed the battery I also hooked up the wiring for heated gear.  I have the Powerlet Rapid Fire setup.
« Reply #10 on: January 01, 2014, 05:00:26 PM »
You probably should get the 3/8ths socket variety.  They work better.
« Reply #11 on: January 01, 2014, 05:05:03 PM »
Meh- no problem with either of those either, just send them out to Jay and he can run them through with his next batch of C-14 parts being painted.
