Author Topic: Idle speed  (Read 21858 times)
Offline mtn.connie
Idle speed
« on: June 09, 2011, 10:08:04 AM »
2011 w/ 500 miles. It is idling at 1000rpm. Once in a while it cuts out at a stop. Should the idle be higher?
Re: Idle speed
« Reply #1 on: June 09, 2011, 10:09:20 AM »
Yes, 1200-1250.  Shifting will smooth out as well.
Offline Truerider
Re: Idle speed
« Reply #2 on: June 09, 2011, 10:31:20 AM »
Well that answers that question,I always thought my idle was a little too high,but that is what it runs at.
Cool thanks 8)
Offline CrashKLRtoConnie
Re: Idle speed
« Reply #3 on: June 09, 2011, 11:41:19 AM »
I did not know the 2010 has a different idle speed than the 2008?
I saw that Kawasaki lists 2 different idle speeds for the 2008 ABS C14 (California)
2008 Kawasaki Spec Sheet (off OEM web page) for 2008 C14 ABS lists idle speed at 1000 +/- 50 RPMs
2008 C14 ABS owners manual page 185 lists idle speed at 1050 - 1150 RPM
Not sure which is correct. I have been using the owners manual ~ 1,100 RPM.
I may try the 1250 as smoother shifting would be nice.
2008 C14 GTR1400 AKA "Connie"
Re: Idle speed
« Reply #4 on: June 09, 2011, 12:48:59 PM »
Do you want to do what the manual says or do you want it to work (this is to no one in particular)?  Set it to 1250 or so and forget about it.
Bob
Re: Idle speed
« Reply #5 on: June 09, 2011, 12:57:44 PM »
Yes, Yes! 1,200-1,300 worked great on my 08!  ;D
Offline skeet
  • 2009 Concours 14
Re: Idle speed
« Reply #6 on: June 09, 2011, 01:22:01 PM »
my '08 likes it better at 1200-1250 as well
Re: Idle speed
« Reply #7 on: June 09, 2011, 03:21:49 PM »
Do as Jim commands!!!!!!
Excavator
Re: Idle speed
« Reply #8 on: June 09, 2011, 03:47:53 PM »
When I picked mine up new it was over 1300,  I took it down to 1150 and it works great there. I'm sure some do better at higher idle but mine likes 1150......Shifts great.
Flathead
Re: Idle speed
« Reply #9 on: June 09, 2011, 04:32:28 PM »
OP, in case you didn't know there is a little silver knob on the lower left side, in front of and below the shifter, for adjusting the idle so it's easy to fiddle 'til she runs good for you  ;D
Offline So Cal Joe
Re: Idle speed
« Reply #10 on: June 10, 2011, 07:31:33 AM »
My 09 was at about 1200+ when it was new, at 600 mile service I asked the dealer if that was a little high because it had a loud clunk going into first from neutral, he adjusted down to about 1050 - 1100 and I still get a slight clunk when going into first gear but all the rest are good.
Re: Idle speed
« Reply #11 on: June 10, 2011, 09:12:58 AM »
+1!
Re: Idle speed
« Reply #12 on: June 10, 2011, 03:37:07 PM »
Its 1150/1200 for me.
Re: Idle speed
« Reply #13 on: June 10, 2011, 06:26:53 PM »
Clunk is normal....
Excavator
Re: Idle speed
« Reply #14 on: June 10, 2011, 06:54:09 PM »
Clunk is normal....
Mine does not clunk as hard after lowering the idle.
Offline metzgerf16
Re: Idle speed
« Reply #15 on: June 11, 2011, 02:53:12 AM »
I had to turn my idle down as well.  Still get a clunk, but I like it.  There's no mistaking that you put the bike in 1st gear.
"You serious, Clark?"
'09 Red Concours- Sargent seat, Area-P exhaust, BMC filter, PC-V, flies out, PR2's, Murph's risers
'06 Ninja zx10r- Dear tiny baby Jesus, it's fast!
Offline booger
Re: Idle speed
« Reply #16 on: June 11, 2011, 06:46:54 AM »
I use my gear indicator ;D
Re: Idle speed
« Reply #17 on: June 11, 2011, 11:58:47 AM »
Suzuki "clunk" into 1st is worse in my opinion.
Bob
Re: Idle speed
« Reply #18 on: June 11, 2011, 02:30:45 PM »
No way. By far a Harley Davidson clunking into first gear is by far the hardest clunk you'll ever hear out of a motorcycle transmission. Good thing those Harley trannys are just about bullet proof!
Re: Idle speed
« Reply #19 on: June 11, 2011, 02:39:25 PM »
I was just comparing to the Kaw, yes Hardly Ablesons are the worst into first. :)
