Author Topic: Cap on front bevel drive  (Read 4932 times)
Offline rotorbike
  • Country: ie
« on: October 20, 2013, 01:34:30 PM »
Hi,
Does anyone know how the black plastic cap is removed on the front bevel drive? My bevel is suffering from corrosion and needs a respray but the manual asks you to use a special Kawasaki part to remove the cap.
Is it pushed on or threaded? Is there an easy way of removing it undamaged without the tool?
Thanks in advance.
« Last Edit: October 20, 2013, 03:29:53 PM by rotorbike »
Re: Cap on front bevel drive
« Reply #1 on: October 20, 2013, 05:13:11 PM »
Can you post a pic? I'm not sure which cap you're referring to.  ???
Offline rotorbike
  • Country: ie
« Reply #2 on: October 21, 2013, 01:52:39 AM »
« Reply #3 on: October 21, 2013, 04:53:43 AM »
Actually....no.  The link isn't working.
Offline pistole
« Reply #4 on: October 21, 2013, 05:07:04 AM »
- there is ALOT OF OIL behind that round black plastic cap. Its not meant to be removed and needs no "oiling" as its part of the oil bath for the gearbox/front bevel drive.
« Reply #6 on: October 21, 2013, 08:31:29 AM »
I thought the front bevel gear was being oiled from the engine/transmission oil. It gets new oil when you change the engine oil. (Someone correct me if I'm wrong.) So I'm curious how you know your front bevel is "suffering from corrosion" if you can't get the cap off to see it?
« Reply #7 on: October 21, 2013, 12:53:28 PM »
My manual just says pry it off with a tool...
'Pry off the gear case cap [A] with a tool.'
Doesn't say anything about the tool being 'special'.
The only special tools mentioned in the section 'Front Gear Case Disassembly' are:
Drive Gear Holder and Bearing Driver Set....
Based on what I see in my manual, there aren't any threads on it.
Offline rotorbike
  • Country: ie
« Reply #8 on: October 21, 2013, 03:09:54 PM »
Many thanks.
Hopefully it will still be usable after prying!
Offline Spanky
« Reply #9 on: October 21, 2013, 03:15:56 PM »
Hey now, No prying with your tool in public   :o
« Reply #10 on: October 21, 2013, 03:49:45 PM »
While you have it apart you might as well powder coat that bevel drive black...  8) :thumbs:
« Reply #11 on: October 21, 2013, 05:24:36 PM »
Sigh...
Offline RBX QB
« Reply #12 on: October 21, 2013, 05:40:57 PM »
Sigh...
A link to the other thread would have been too subtle.
2011 Concours 14 ABS
« Reply #13 on: October 21, 2013, 07:52:15 PM »
Offline rotorbike
  • Country: ie
« Reply #14 on: October 22, 2013, 02:41:48 AM »
Why power coat it when mine looks this good
« Reply #15 on: October 22, 2013, 04:28:57 AM »
 :o
WTF happened to that thing?
« Reply #16 on: October 22, 2013, 04:53:18 AM »
 :yikes: and  :yikes: :censored: ...  Mine still looks brand new....and that's with only washing it once a year!
« Reply #17 on: October 22, 2013, 08:38:06 AM »
I get it. It's not the bevel gear it self that is corroded but the housing. East coast? Lots of salt?
Offline PH14
« Reply #18 on: October 22, 2013, 10:30:54 AM »
Possibly washing it with brake fluid? :_shudder_Emoticon
« Reply #19 on: October 22, 2013, 10:59:25 AM »
 :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes:
