Speed and power is the most powerful narcotic known to man.
Took the 182 up today. It's an older model (182Q) with 4,000 hours on the airframe, but everything works nice. Front tire is way out of balance though, ask me (and my CFI) how I know this
The plan was to get practice in a hi-perf airplane. CFI said we should work on some mountain flying since I live in them. In simple terms, the 182 flies JUST like the 172, but has one more knob to pull (prop), and seems to have unlimited power.
OAT around 15C, DA not a major factor, roll out on 11, depart the pattern to the SW and keep climbing toward Corona Pass (not a road, not on 'normal' maps). 80-90kts, 400-500FPM climb, level off around 13,000, close cowl flaps. Sweet, I like this, I like this alot
Cross Corona Pass (attached pix), start a power on decent to Granby. NO traffic, cool, no distractions either. Base leg is heading RIGHT toward the side of a hill. Very last minute, turn base. I turned a bit too soon, made a crappy base-final turn. But it worked out. The 182 lands better than the 172 also! Either that, or I'm getting better
Taxied back for departure, did an abbreviated 'max RPM' runup and took off. Granby field is 8207 FWIW. Heading west toward Kremmling (7400' elev.) I barely got back to pattern altitude then followed the Colorado River drainage (and/or US 40) toward Kremmling. King-Air on the Kremmling runway someplace. He was from the SW, music to listen to, but hard to get meaningful info from him. We asked location, he replied rolling... Uh-huh, rolling exactly where!?
We (I) did a straight in, he was taking off in our direction. I kept to the N (right) for no apparent reason
we saw him 3 miles at 11:00 and 300-500 above. Cool, back on centerline, flaps, power, prop...
Exited the runway, recomposed, taxied back and took off to the west. Fairly sharp RH turn once 500AGL, paralleled a mesa (above me) on the left, and Kremmling to the right. Climb, adjust mixture, fiddle with radios, close cowl flaps, fiddle with cabin heat, knobs, buttons, levers... Cross Corona Pass again, head toward Casa Hall. 9000 MSL, couldn't see the house very well, kinda made my CFI nervous given I was descending (I live at 7400 MSL) in a mountain valley, but it was all down hill, and LMO was in sight.
Straight in to LMO with one plane in closed pattern. Called straight in if traffic accomodates, good landing but slightly skewed on touchdown (more left rudder).
1.8 Hobbs time for the whole event. By car it'd be 4 hours to Granby *only* and back, *IF* Trailridge Road was open (That's the road through RMNP)
Max IAS was around 140kts. I did a rough TAS in the air at around the same speed. Ground speed varied from 90 to 160kts, we had a 15-20kt wind from the west.
Next up is four hours in the same plane this Friday. LMO to LXV (Leadville, 9900', highest GA airport in USA), then GWS (Glenwood Springs, 5540'), then maybe Steamboat Springs area (Hayden? at 6600'), and back home.
Speed and power is a narcotic...
Rick
