Not for C-10 but an interesting question.
We have a bus at work. It drains the battery overnight. Sometimes it does, sometimes it dosen't. Took it to the shop. They said pull out this fuse, a 50 amp one. So every night the driver parks the bus & pulls out the fuse. The battery never dies with the fuse pulled out.
So don't go screaming on the mechanic, this is Atco, NJ. Using 3 syllable words will get you elected mayor, or a burning cross on your front lawn. Kind of depends..............
Sounds like a stuck relay to me. I do not have a wiring diagram. So the question is, how can you figure out which relay is attached to which fuse without a diagram. Is there a way to test a relay to see if it's on at the relay or at the relay block? The set up is what you expect, a block of about 20 fuses right next to a block of about 8 relays under the hood.
I asked the person who shold know, fat chance around here, if the bus will run with the fuse pulled out...YES. When the bus is running, what is missing with the fuse pulled out...some of the tail lights. Seems like something missing for a 50 amp fuse.
Any ideas?
Thanks
