Author Topic: What type/size wrench to remove outside saddlebag cover from C-14???  (Read 3446 times)
Offline Ninjawarrior
Am trying to replace my scratched outside saddlebag cover with a new one.  I cannot remove it as it has a special type bolt that has a hole thru the center of it, which is NOT an allen type bolt/screw.
So cannot remove it.  I can of course remove the hinge using the 4 standard bolts and capnuts inside the saddlebag, but the hinge is attached to the outside cover and I don't have or don't know what type of wrench or device to remove it.
I know this is done for security reasons by Kawasaki, so any help would be appreciated to I can resolve and replace this outside cover.
Ninja
Re: What type/size wrench to remove outside saddlebag cover from C-14???
« Reply #1 on: August 12, 2013, 08:51:46 AM »
That special 'bolt' is otherwise known as a pop rivet.
Offline ljcorby
  • COG#: 9359
« Reply #2 on: August 12, 2013, 09:00:51 AM »
+1  Just select the correct size drill bit (a little bigger than the center hole or the current pop rivet) and drill it out.  Once you have all the pop rivets out, you will need to put new pop rivets in after installing the new cover.  Advance Auto parts or Autozone may rent you a pop rivet gun if you don't have one.
10 Kawi Concours 14 ABS
« Reply #3 on: August 12, 2013, 09:01:11 AM »
LOL :)
Yep.  It has to be drilled out and then re-pop-riveted or changed to a bolt or whatnot.
Offline PH14
« Reply #4 on: August 12, 2013, 09:07:31 AM »
This forum never fails to entertain.  :rotflmao:
Offline wroman
  • 2012 C14
« Reply #5 on: August 12, 2013, 11:41:27 AM »
  Easy boy's, let's make everyone fell welcome.  Remember there are no stupid questions only stupid answers.  You can also buy a pop rivet gun at harbor freight cheep.  If you do a search for pop rivet you may find the equal SAE size which I believe is 5/32 or order the ones from Kawasaki.  You will need 5 per side.
I always wanted to be somebody......I guess I should have been more specific.
« Reply #6 on: August 12, 2013, 12:22:57 PM »
I beg to differ about the 'there are no stupid questions' statement.
A while back we had a guy come here and he wanted to know how to get the chain cover off of his C14 so that he could do some maintenance on it. The rear wheel drive chain...   :o
« Reply #7 on: August 12, 2013, 01:08:00 PM »
 :doh: :rotflmao:
One does well here if they can take a bit of ribbing in order to get an answer.  We're an equal opportunity (we make fun of everyone) forum.
Offline RBX QB
« Reply #8 on: August 12, 2013, 01:46:46 PM »
At least (mostly) helpful responses were provided... That's better than usual.
2011 Concours 14 ABS
« Reply #9 on: August 12, 2013, 03:58:05 PM »
This almost fits the OP's description. So the question has some merit.
Offline RBX QB
« Reply #10 on: August 12, 2013, 04:18:12 PM »
... but DON'T use those on your bike! Most of those are soft aluminum. I use those to bind drawings together.
Of course, if you MUST use them on your bike, please provide video of a spirited ride with full bags, aimed at where these were installed.
« Reply #11 on: August 12, 2013, 05:00:02 PM »
Thought that was what red locktite is for.
« Reply #12 on: August 12, 2013, 05:19:51 PM »
Humor mixed with a good recommendation......excellent!  Key word 'were'.
Offline PH14
« Reply #13 on: August 13, 2013, 09:02:37 AM »
Due to the soft aluminum, I'm not sure locktite would help. They may actually break due to stress. I would stick with the proper rivet.
« Reply #14 on: August 13, 2013, 10:58:03 AM »
I guess I'm going to have to use those stupid smilies.  :)
Offline PH14
« Reply #15 on: August 14, 2013, 12:52:03 PM »
Probably. It might help.
