My Dad found a cure for a cat p__s___g on his garage door.
NOTE: Dad was a Model T Ford nut.
He put a piece of metal on the door and on the ground, and wired a Model T coil to it.
When the cat did his deed, he completed the circuit and received the voltage that goes to a Model T Spark plug. (about 25,000 volts).
The spark went directly up the err liquid path.
That cat
NEVER EVER p____d on Dads garage again..
NOTE: Spark plug volts are high volts, not high amperage.
It won't kill ya, but it will make you wish you were dead.
If anyone has ever touched a spark plug, you'll understand.
