I think you already got some excellent thoughts and advise. I will just repeat what has already been said that I believe is exactly correct: you have suffered a loose battery cable or battery to frame cable connection. Disconnect, clean and reinstall both cables on the battery as well as the ground cable where it attaches to the frame and I think you will be all set.
It cannot be the kill switch because as many have said, that would not cause all power to be lost on the bike, only the engine.
It cannot be KiPass although that is always the first thing you should blame under any circumstance and for any problem.
But in fact KiPass cannot interfere with the running of the bike, only the starting of the bike; KiPass simply cannot stop the bike from running.
In the olden days, once a car was running you could disconnect the battery and it would continue to run as long as the alternator was working; in other words, the alternator would provide all power needed to run the vehicle indefinately. Modern vehicles, starting back in the '80's it seems, stop running immediately when the battery is disconnected even when the alternator is performing correctly. So I suspect a C-14 will do this also and a loose battery cable will shut everything down on the bike when the connection is broken.
If it is not a loose cable, then it may be the circuit between the battery and the main harness, and that circuit includes the main fuse which is located next to the starter solenoid behind the battery. I really do doubt it is that that is causing your problem but it is possible.
Best of luck with the fix.
Hi, all.
I had a terrifying experience last night so I would like to ask if anybody had an idea of a cause.
<snip>
So please share your thoughts and experiences (if any).
Thanks in advance
Gordan
