Author Topic: Headlight lowbeam dim  (Read 5545 times)
Offline toon
« on: June 05, 2011, 09:59:09 PM »
Hi,
Long time lurker, first time poster. I had the lowbeam go out on my 88 c10 (the fastest color). I have replaced the bulb but no help. when the low beam is selected the head lamp indicator is lit on the dash and the bulb is dim. I think I remember this being discussed on the old forum as a switch issue. I wanted to check with the experts here before I started with the screwdriver.
Thanks
Alton
Any landing you can walk away from is a good one
88 connie (rear ended)
12 Ural, 16 KLR
09 Connie
Offline Outback_Jon
Re: Headlight lowbeam dim
« Reply #1 on: June 05, 2011, 10:17:41 PM »
I don't know if it may be a switch issue, but it sounds like the "Reserve Lighting Device" is kicking in.  This is a circuit that keeps a light on in the headlight when one of the filaments burns out.  Sounds like the bulb you put in as a replacement is defective.
Offline toon
« Reply #2 on: June 05, 2011, 10:20:46 PM »
Thanks outback. I should have a new one from murphs in the mail box when I get home. I'll try that.
Toon
12 Ural, 16 KLR
09 Connie
Offline toon
« Reply #3 on: June 16, 2011, 12:51:09 AM »
Ok, I've changed the bulb 3 times now. No help, still the same dim light on low beam and Head lamp indicator on dash lit. What else should  I be checking? Fuses? Broken wire? My next step will be to use a test light or volt meter to check wiring. Any help would be appreciated.
Toon
12 Ural, 16 KLR
09 Connie
Offline SteveJ.
« Reply #4 on: June 16, 2011, 09:49:17 AM »
Toon
That would be my next step, start at the headlight connector and work back in the circuit.
America's Seaplane City
Offline Pfloydgad
« Reply #5 on: June 16, 2011, 07:16:34 PM »
Through a volt-ohm meter on the hot line to check voltage to the light. I bet there is a drop off from a cut or break in the wire. The ground could also be damaged, it could be pulling the citcuit down. Trace it back all the way to the j-box.
Good luck, and ride safe.
Greg
Offline DaveO430
« Reply #6 on: June 16, 2011, 07:46:05 PM »
If the high beam works it rules out a ground problem.
I get a chuckle out of the troubleshooting in the manual.
"If all wiring and components other than the reserve lighting device check out good, the device is defective"
Offline toon
« Reply #7 on: June 16, 2011, 10:08:05 PM »
I will work on it this weekend. I'll let you know what I find.
toon
12 Ural, 16 KLR
09 Connie
Offline toon
« Reply #8 on: June 21, 2011, 12:40:27 AM »
Ok, Update time....
I did not have a chance to trace the wiring over the weekend (moving household took longer than I planned). While on the way to work tonight the low beam started to work. I only noticed after I took pity on the car in front of me at a stoplight and turned off the high beam. Now no Head Lamp indicator light and a bright low beam. So now I will have to wonder what was wrong and be happy I am lucky enough to own the rare self correcting Concours.
Untill the next dark saga,
Toon
12 Ural, 16 KLR
09 Connie
Offline m hanlen
« Reply #9 on: June 21, 2011, 11:27:40 PM »
Ok, Update time....
Toon
Sound like you've got an intermittent bad ground, probably the blade plug on the back of the light. Probably got hot and melted.
Offline toon
« Reply #10 on: June 22, 2011, 09:57:34 PM »
Thanks. I will check that.
Toon
12 Ural, 16 KLR
09 Connie
Offline toon
« Reply #11 on: August 02, 2011, 11:56:58 PM »
I need a little help.... started to check the wiring and found what i think is a modulator????? can i just remove this and plug the original wires in?  or are the OEM wires removed when the unit is installed?
Thanks Toon
12 Ural, 16 KLR
09 Connie
Offline toon
« Reply #12 on: August 09, 2011, 02:09:34 AM »
OK...
Fixed the problem. Modulator was shorting the low beam. Removed..plugged in original plug. no more problem.
12 Ural, 16 KLR
09 Connie
