Keep in mind that Kawasaki offers accessory windshields, so they cannot deny coverage simply based on the fact that the windshield was swapped. Obviously the motor can accept the impact of a different (larger) shield. The burden is on them to demonstrate that the failure occurred because of the aftermarket part, and that failure would not have otherwise occurred (for example, that the accessory Kawa shield would not have caused failure). If you put a 4x8 sheet of 3/4" MDF as your shield, then they could argue weight/wind-resistance grossly exceeded the limits of the motor. But if you use a shield of similar design/construction to what Kawa offers, then I think they'd have a difficult time saying you did anything wrong.
have you compared the shield he says is installed, with the OEM stock one, or the slightly larger accessory Kaw sells?
Evidently not... because it IS substantially larger
![Roll Eyes ::)](http://zggtr.org/Smileys/default/rolleyes.gif)
and heavier......
more like 1" pressure treated exterior grade....
![Cry :'(](http://zggtr.org/Smileys/default/cry.gif)
with that said, they actually CAN say it caused the problem.
Now, whether they will or not depends... if you bought the C Baily thru the dealer, and had them install it without an argument, then it's on them....and they then cannot deny, if not... open argument.
BH, not sure of where you are located, but maybe if you post and ask nicely (start another post, or change the title of this one to "CAN YOU LEND ME A WINDSHIELD FOR A DAY?" someone would lend you thiers.... I'd do it for you if you were in my neighborhood....
Putting back the original shield and taking the bike to Kawa with "no idea what happened, it just stopped working" face is dishonest, and if Kawa decides to step up and cover it anyway, it will be the rest of us paying for your repair. (I'm not referring just to the OP here, but to anyone endorsing this behavior)
sorry Martin, but the only people Paying for his repair are the people that made the bike...ok?
we ALL know that the shield should be fine, and KAW has known since we started biotching about the shield from day one it need to be re-done...so they made a bigger one...
I hate to be a party pooper, but preaching about him wanting it fixed under warranty ain't gonna get it here, we have all been here long enough to know "when it comes to getting a warranty repair, get what you can get, any way you can get it!!"
we been buying extended warranties for years now, and if we never use them, god bless him for getting his repairs.
with the way dealers deny legitimate repairs out there today, that I read about DAILY, there is no way i feel sad for them...
