Author Topic: Tire bead seating  (Read 2602 times)
Offline Awaz
Tire bead seating
« on: July 05, 2013, 09:41:43 AM »
I decided to make a new topic on this - hopefully that is ok. I finally put my tire on and aired it up. I noticed that there is like 1/8th or so gap between the edge of the rim and the tire. I know the bead sat because there was two loud pops and I am not losing any air. I deflated it twice and inflated and still the small gap persist. Do not think I have seen these on any of the four tires I have mounted so far. Want to find out if this normal. The gap is all around uniformly on both sides.
Edit: did some search and found that some tires come with a rim protection feature that makes the bead seat a bit below the lip of the rim. I did not quite find if this particular tire has that feature, but gonna assume that is the case.
« Last Edit: July 05, 2013, 11:54:13 AM by Awaz »
2016 Ducati Scrambler
2008 C14
Offline GeeBeav
Re: Tire bead seating
« Reply #1 on: July 05, 2013, 01:17:05 PM »
 :popcorn:
Offline Outback_Jon
« Reply #2 on: July 05, 2013, 01:55:28 PM »
That absolutely does not look right.  I don't see how that could be a "rim protection feature", either.
I wouldn't ride on it.  At least until I had some sort of professional opinion about it.
« Reply #3 on: July 05, 2013, 03:03:42 PM »
No way.... Rim protective bead I have on our SUV and it amounts to an extra deep profile so that the rim is deeper within the tire itself; this protects the rim from mean curbs...
« Reply #4 on: July 05, 2013, 03:41:29 PM »
And so it begins..... :popcorn:   Good luck Awaz.  Hopefully it is seated.  If not, it should be by the time you ride on it for awhile. ;)
« Reply #5 on: July 05, 2013, 03:52:22 PM »
Is it the Dunlop Elite 3 ? Bias or Radial? Would there be a bead difference?
« Reply #6 on: July 05, 2013, 05:04:14 PM »
It's both, but Awaz has the radial version.
« Reply #7 on: July 05, 2013, 05:09:43 PM »
...but should he?
Offline Outback_Jon
« Reply #8 on: July 05, 2013, 06:37:07 PM »
Is the gap on both sides?
I'd deflate it, break both beads, spray some tire lube in there, and re-inflate.  Get some good pressure in there, too.
« Reply #9 on: July 05, 2013, 08:29:19 PM »
Sounds complicated..
« Reply #10 on: July 05, 2013, 08:38:45 PM »
That's what she said...  ;)
« Reply #11 on: July 05, 2013, 09:32:49 PM »
great excuse to buy Michelins  8)
Offline Awaz
« Reply #12 on: July 06, 2013, 03:04:32 PM »
Talked to Jake Wilson rep and did some research:
http://www.m109riders.com/forums/showthread.php?t=140235
Looks like the darn tire is made for an 8" rim instead of 8.5". Talk about my sucky luck.....
2008 C14
