Author Topic: FOB problems ?  (Read 11259 times)
Re: FOB problems ?
« Reply #20 on: June 14, 2013, 07:20:06 AM »
So will that stuff help corrosion on the board?
or is that just contact cleaner.
Yep, it'll clean up the corrosion too. I used it at work and at home all the time.
The Caig Laboratories D100L-2DB is a DeoxIT® contact cleaner and rejuvenator in a 7.4ml bottle with a brush applicator.
Caig Laboratories D100L-2DB Features:
Acts as a unique contact cleaner, rejuvenator, conductivity enhancer, and lubricant
Dissolves oxidation and corrosion on metal surfaces
Fills in microscopic gaps and reseals surface for better contact to improve flow of electricity
Reduces intermittent connections, arcing, wear, and abrasion
Temperature Range: -29°F to 392°F
7.4ml bottle with brush applicator
RoHS and VOC compliant
http://www.all-spec.com/products/D100L-2DB.html
See this .pdf for more info on what DeoxIT can do for water damage.
http://www.zggtr.org/MGalleryItem.php?id=488
« Last Edit: June 14, 2013, 08:51:52 AM by Conrad »
Offline PH14
Re: FOB problems ?
« Reply #21 on: June 14, 2013, 08:33:10 AM »
I'll have to get some tomorrow all I have is 50% on hand
I washed it about a month ago and thought all was well  :'(
So dielectric silicone compound is a no no ?
I screwed up my truck key door opener type thing (Dodge) while kayaking (salt water ) does the same thing, works for a while then _____
Where do you get 99%
Glad this one is my spare .
91 percent is available at most drug stores. 99 percent is available on Amazon but unless you have a Prime account and have it shipped quickly at no cost there is no real advantage. Get the 91 percent and use it. If you actually see corrosion you can use an electronics cleaner but be sure it says it is safe on plastics. I have some from Radio Shack that is, but whatever you do don't use the kind with a lubricant in it. I personally think you could simply wipe off the connections, replace the battery and all would work fine after the water dries up.
Re: FOB problems ?
« Reply #22 on: June 14, 2013, 06:06:05 PM »
Instead of using alcohol I'd recommend using a good contact cleaner. Hands down the best contact cleaner/restorative that I've used is Cramolin. It'll clean the contacts and keep them from oxidizing.
Cramolin?  Interesting name.
Re: FOB problems ?
« Reply #23 on: June 14, 2013, 06:25:41 PM »
Will that stuff clean the white crud from around the gashole?
Re: FOB problems ?
« Reply #24 on: June 14, 2013, 06:35:59 PM »
You'll have to ask Conrad, but I suspect that it will.
Re: FOB problems ?
« Reply #25 on: June 14, 2013, 06:38:22 PM »
You think he'd know?
Re: FOB problems ?
« Reply #26 on: June 14, 2013, 07:10:44 PM »
He recommended it highly.
Offline Cuda
Re: FOB problems ?
« Reply #27 on: June 14, 2013, 07:18:16 PM »
Thanks Conrad
Radio Shack part # 640-4338 $14.99 two little cans
DeoxIT  Mini -Sprays Connector Cleaner & GOLD G-series contact conditioner/protector
www.caig.com
Just what I was looking for
Amen brother
Gods waiting room Naples
2011 Atomic  Silver
Re: FOB problems ?
« Reply #28 on: June 14, 2013, 08:21:39 PM »
Assuming that white crud around your gashole is corrosion, I bet it would. It that white crud is something else you may need a different type of.... er, cleanser.
But on a serious note, that white crud almost certainly is corrosion. I use a light oil to clean it up and leave a touch of oil behind (no pun intended) wherever I find any corrosion. For some strange reason, I have had good results using automatic transmission fluid (ATF)- I have used it in a pinch quite a few times only to find it seems to last. Works great around battery terminals without leaving gobs of grease behind (again, no pun intended).
Re: FOB problems ?
« Reply #29 on: June 15, 2013, 01:32:58 AM »
Yeah, right.  No pun intended.  I don't believe that for a second.
Re: FOB problems ?
« Reply #30 on: June 15, 2013, 07:00:24 AM »
I keep my gashole very clean so I wouldn't know about this.    :-X
Re: FOB problems ?
« Reply #31 on: June 15, 2013, 07:01:07 AM »
Thanks Conrad
www.caig.com
Amen brother
 :thumbs:
Re: FOB problems ?
« Reply #32 on: June 15, 2013, 07:11:18 AM »
I always keep wet wipes in the side case for the gashole, you never know when it might need to be cleaned up.
Re: FOB problems ?
« Reply #33 on: June 15, 2013, 07:42:53 AM »
Thank you for that.  Now can you make him clap his hands?    Ah, the good ole days...  :)
Re: FOB problems ?
« Reply #34 on: June 15, 2013, 07:51:36 AM »
Let me try to find that Joker with the clap.
Offline Cuda
Re: FOB problems ?
« Reply #35 on: June 15, 2013, 08:24:10 AM »
Word for the day Hyperbole
http://youtu.be/qLezXLuvNgc
2011 Atomic  Silver
Re: FOB problems ?
« Reply #36 on: June 15, 2013, 04:57:48 PM »
For some strange reason I cannot get the clap.  :(
Re: FOB problems ?
« Reply #37 on: June 15, 2013, 04:57:55 PM »
A shot of penicillin with clear that right up.
Re: FOB problems ?
« Reply #38 on: June 15, 2013, 04:58:48 PM »
How about a shot of bourbon?
Re: FOB problems ?
« Reply #39 on: June 15, 2013, 05:04:23 PM »
If you're buyin I'm drinkin.    :chugbeer:
