Author Topic: Murph's brake line  (Read 7676 times)
Offline toojeep4u
Murph's brake line
« on: June 04, 2011, 05:21:37 AM »
Installed a set of 2 lines on the front brakes last night and I can feel a huge difference when I squeeze the handle.  I left it clamped all night and now the lever doesn't even come close to the throttle when I grip it.  I haven't had a chance to ride it yet as it is still apart awaiting the install of new rear and clutch line today.  The fronts went in easy enough but the fittings don't make sense.  I followed the instrctions on Murph's site, but I don't see why the left line would have a slight kick at the fitting on the resivoir end.  It puts it in a slight bind.
Tori '01
Offline throb
Re: Murph's brake line
« Reply #1 on: June 04, 2011, 05:49:46 AM »
There shouldn't be any binding if you either offset the fittings slightly or position them like the photo shows in the directions on Murph's site.  The fittings can also be turned to achieve the proper angle as well.
Offline T Cro ®
« Reply #2 on: June 04, 2011, 06:17:28 AM »
Be careful with that statement as not all fittings can be twisted within the hose to change their positions' be sure that the directions that come with your lines clearly state this and includes the tools to do so. Also the reason one fitting has a slight bend in the end is so that it can lock itself in behind the other straight fitting. I also find that it helps to grind off the little tang that hangs off of the master cylinders so that you can position the lines as you so desire.
Tony P. Crochet
Offline throb
« Reply #3 on: June 04, 2011, 06:47:35 AM »
  True;  was going on the statement the OP bought them from Murph, hence Spielgler lines which should have the adjustable banjos.  Provided of course they send you the block to clamp the fitting and the extra heavy duty piece of plastic to twist it with!
Offline T Cro ®
« Reply #4 on: June 04, 2011, 06:53:33 AM »
BTW that block and rod are a piece of junk... I used a pair of channel lock plyers and a close fitting metal rod to twist mine; it was very easy that way.
Tony P. Crochet
Offline toojeep4u
« Reply #5 on: June 04, 2011, 06:58:12 AM »
So the banjo on the end can be rotated?  That would work better.  I wondered what the block and pin were for.
Tori '01
Offline Tele130
« Reply #6 on: June 04, 2011, 07:01:13 AM »
Hey Tony,
  Mine worked pretty well.  Don't know if I could do three or four sets using the same "Vice Block", but it worked ok. ;D  FWIW, I LOVE having real brakes on the Connie :chugbeer: :thumbs:
Doug Colton
Offline Tele130
« Reply #7 on: June 04, 2011, 07:03:56 AM »
Make sure when you place the block in your vice to tighten it.........................follow the instructions (The block should start to change color, if I remember correctly).
You are using Spielgler lines right?
Doug Colton
Offline T Cro ®
« Reply #8 on: June 04, 2011, 07:04:48 AM »
Hey Tony,
Yeah the hard part was parking the bike on the work bench close to the bench vise...... :P
Tony P. Crochet
Offline Tele130
« Reply #9 on: June 04, 2011, 07:07:29 AM »
 :rotflmao: Yea, that was a total drag.  Did you just power lift it or did you have help?
Doug Colton
Offline T Cro ®
« Reply #10 on: June 04, 2011, 07:09:25 AM »
I used a ramp!
Tony P. Crochet
Offline Tele130
« Reply #11 on: June 04, 2011, 07:22:14 AM »
I used a ramp!
See?  Never thought about that  :nuts:
Doug Colton
« Reply #12 on: June 04, 2011, 01:43:05 PM »
I have found the Galfer lines to fit without any problems....or needing to grind anything off...
A piece of clear plastic tubing on the original hoop assists in making a nice routing also, you can remove the old block and bolt it on there...
good luck on the clutch line, resign yourself to snip the metal tube at the mid point, it's much easier to remove it than trying to fish it all out...which is a p.i.t.a., and requires lots of disassembly...
routing f.y.i.
Offline T Cro ®
« Reply #13 on: June 04, 2011, 01:48:44 PM »
MOB it's not that they didn't fit it's that they fit mo better when you can direct them in ANY direction not hindered by the tab gettin in the way.
Tony P. Crochet
Offline toojeep4u
« Reply #14 on: June 05, 2011, 09:15:44 AM »
Now this is how I thought they should go but the angled banjo didn't line up with the banjo on the caliper.  I didn't realize you could rotate the banjo on the line.  I have it like the pictures shows on Murph's site.  But I don't like the way it angles back toward the handle bars.  Of course now I have it filled and bled.
Tori '01
Offline toojeep4u
« Reply #15 on: June 06, 2011, 11:25:35 AM »
This is how mine ended up.  I think I am going to pull the lines off the master again and twist the one angled banjo 180°.  That should fit better.  ALso, is the line running from the rear resevoir to the master cylinder standard hose?  Can I use fuel line for that?
Tori '01
Offline T Cro ®
« Reply #16 on: June 06, 2011, 12:39:49 PM »
If it will stand up to gas I would think that it will stand up to brake fuild.
Tony P. Crochet
Offline GF-in-CA
« Reply #17 on: June 06, 2011, 01:48:48 PM »
I just looked it up, and fuel hose is Nitrile, which is listed as good for fuels but bad for brake fluid, so no go on the fuel hose.  The material to use is EPM or SBR.  Look up "brake reservoir hose" on Google.  I found a couple, but don't know what the size is for C10.  It is used on some VW's and other Euro cars, as well as motorcycles
http://www.pegasusautoracing.com/productselection1.asp?Product=3575
http://www.doghouserepair.com/store/item/3303/
HTH,
Gary F.
1998 C10
California North State
Offline toojeep4u
« Reply #18 on: June 06, 2011, 06:21:42 PM »
HTH,
Good catch Gary, thank you!
Tori '01
Offline Centex
« Reply #19 on: June 07, 2011, 09:16:48 AM »
Here's the page with lots of choices for reservoir (brake fluid) tubing from Yoyodyne, though they don't identify the material.
FWIW I ponied for the expensive (now $8/ft) Yoyodyne clear tubing for a Ducati clutch and front brake master cylinder/remote reservoir conversion in early 2003 .... now 2011 the tubing is still flexy, not swollen, and working fine though very slightly yellowed, so the high $ may be worth it.
YMMV  :)
Alan in Central Texas
2004 Connie COG 9476
2001 Ducati M750
