Author Topic: MAP Sharing  (Read 16884 times)
Offline Steve-UK
Re: MAP Sharing
« Reply #40 on: May 15, 2018, 04:37:41 PM »
Hi guys. Sorry to resurrect an old topic but I’m after some help.
I’ve got a 2011 standard filter and a Two Bros end can and I’m going to remove the flies. I’ve got some stuttering issues when running at low revs. I’ve just installed a PCV and am after a map if anyone can help.
Thanks all
Re: MAP Sharing
« Reply #41 on: May 15, 2018, 06:34:44 PM »
1... leave the flies in, drop the PCV and have the ecu reflashed.
2... Pull the flies and add an Autotune with the PCV.
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: MAP Sharing
« Reply #42 on: May 16, 2018, 08:31:12 AM »
Thanks all
  Rembrandt answered your issue ^. The PC5 can't correct for fueling that's not tps based. You're never going to get rid of that stuttering with a PC5. About the best I think you can do is set your maps to "0" up to about10% throttle.  HTH, Steve
