Author Topic: Well, if it's not one thing it's another.....  (Read 3943 times)
Offline jim_de_hunter
« on: May 16, 2013, 10:01:17 AM »
Speedometer/Odometers quit working on the way into work yesterday....
Offline Mettler1
Re: Well, if it's not one thing it's another.....
« Reply #1 on: May 16, 2013, 04:36:27 PM »
 Speedo cable break?? :o
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #2 on: May 16, 2013, 05:01:32 PM »
Happened to me twice. First time it broke about 2" from the wheel. Second time it came loose at the speedo because someone didn't tighten the replacement cable good enough. Name and address withheld upon request.
« Reply #3 on: May 16, 2013, 05:50:45 PM »
Dunno yet. May be next week before I get to it. I've got to relearn how to find an inverse matrix so that I can decrypt a Vingere code first.
Offline T Cro ®
« Reply #4 on: May 16, 2013, 06:46:47 PM »
Sounds simple enough.....  ???
Tony P. Crochet
Offline Mettler1
« Reply #5 on: May 16, 2013, 08:51:11 PM »
   I've been working on that a long time. Ah yes, the inverse matrix!! :o
« Reply #6 on: May 20, 2013, 05:22:32 PM »
Yep. Speedo cable break about 2 inches from the wheel.  Easy and cheap enough to fix.  Already got one coming from Murph's!!!!
Offline tweeter55
« Reply #7 on: May 20, 2013, 06:50:02 PM »
If memory serves me right, Jim, I rerouted the cable from the bracket on the back LH side of the fender and put it in the bracket that holds the brake cable. Make sure it is TIGHT on the speedo end. See a previous comment. A real PITA to reach.
« Reply #8 on: May 21, 2013, 03:25:54 AM »
Thanks for the tip.  I removed the fender bracket a long time ago because it would stay in the fender.  I had the speedo cable out last summer to grease it.  It's not too bad.  I can replace my clock lamp while I'm at it.  It went out again.
Offline UKFan
« Reply #9 on: May 22, 2013, 09:56:05 AM »
The clock has a lamp?
« Reply #10 on: May 23, 2013, 09:56:52 AM »
Yep.  It's back light so you can see it at night.
« Reply #11 on: May 23, 2013, 07:38:40 PM »
^^^ may have been the prob!?  :D
« Reply #12 on: May 24, 2013, 08:27:06 AM »
Could be.
When I pulled the wheel end of the cable, right at the break was a metal flange was stuck to the break.  I'm figuring something else came apart and the flange bound the cable.
