Author Topic: Freeing up rotor buttons  (Read 8972 times)
Offline clogan
Re: Freeing up rotor buttons
« Reply #20 on: May 14, 2013, 07:49:44 PM »
Cages are a 45 minute job, even for a guy with a bad back!!
Install of fronts involves only 3 bolts. Did mine, including rears, in maybe 20 minutes, tops. Put it on the center stand first.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
« Reply #21 on: May 14, 2013, 07:54:24 PM »
That's too quick, if it is only a one beer job Jim will keep putting it off.  45 minutes is good for at least 2, maybe 3 beers, with a fourth to admire, and fifth to clean up the tools ;D
« Reply #22 on: May 14, 2013, 09:05:02 PM »
If you say so, Mr. "Silverylightblue!!"  :)
« Reply #23 on: May 14, 2013, 10:07:27 PM »
With a hint of green to highlight it's heritage ;D
« Reply #24 on: May 15, 2013, 04:31:38 AM »
Go put em on Sparky, I'll play the role of mod while you're away...
Trust me, no inappropriate pics will be posted while I'm running the show...  ;D :chugbeer:
« Reply #25 on: May 15, 2013, 04:33:34 AM »
My kingdom for a Time Lord.  You know there's never one about when you need one...  My problem dear Max is time or lack thereof.  I'm working various weekends and the ones I don't I'm with the family.  Now that it's staying lighter I have more time after work but the kettle is on the boil and we're so easily called away.....anyway you get the point, I'm sure.  I'm also replacing a rear tire and changing the battery in the rear TPMS.  So much work so little time...
Sing it with me now.
Hands across the water water, heads across the sky.
« Reply #26 on: May 15, 2013, 04:37:52 AM »
« Reply #27 on: May 15, 2013, 04:39:03 AM »
I can actually hear that song in my head under the helmet....so that's where the voices come from.
« Reply #28 on: May 15, 2013, 04:39:59 AM »
To everyone, nothing takes me 20 minutes to accomplish.  I have to actually think about it for awhile.  I guess I'm much like an Ent in that regard.  What usually happens is that I lose a screw or bolt, have to go to the hardware store, get distracted while there, then forget why I'm there, make a trip to the antique store down the road, then get a coke Icee at Burger King, and then it's beer time and darkness has fallen and I'm back on the forum again.  I just don't have any free time at all.
« Reply #29 on: May 15, 2013, 04:59:22 AM »
Hey, what's that shinny thing over there in the corner?
« Reply #30 on: May 15, 2013, 05:22:07 AM »
The story of my life...  For example, I needed to order a soldering gun this morning.  It took me at least 30 minutes to do so as I kept on being distracted.
Offline tjpgi
« Reply #31 on: May 15, 2013, 06:53:55 AM »
I tried that trick.....didn't work....much.   The first one I tried moved just a very tiny bit and I couldn't get any more movement out of it.  Not like those youtube videos show.
I should have stated my rotor buttons are OEM not EBC ( didn't think about square buttons :o)
2011 GSXR 1000
2009 Concours ABS
1976 KZ900
1991 Sportster XLH 1200
« Reply #32 on: May 15, 2013, 08:35:35 AM »
« Reply #33 on: May 15, 2013, 10:34:50 AM »
 8) :thumbs: :chugbeer:
« Reply #35 on: May 15, 2013, 10:38:57 AM »
^^^^^^^ correct buttons to be discussing
« Reply #36 on: May 04, 2018, 07:37:34 PM »
I actually have replacement brake pads now, real Kawasaki ones.  Assuming the weather and my friend will cooperate, I might have front pads replaced tomorrow.
But I do have what feels like a little bit of warp which is especially noticeable at lower speed with lighter braking.  I remembered the talk about the bobbins, and think I should probably try to free and clean them.  Saw this interesting video:
https://www.youtube.com/watch?v=mZ0cVRfw14A
So I might try it to see if it helps.  Not sure if I should try any type of lubricant or just brake cleaner.   Don't like the idea of any lubricant getting near the rotors.  Hmm.
« Reply #37 on: May 05, 2018, 09:06:24 PM »
Used the method in the video, with brake cleaner only.  It actually works.  Takes a while, though.  So far, the slight feeling of warpage seems to be gone, although I didn't ride it much (just highway back home).  Time will tell...
