Author Topic: Major Screwup? - Synthetic  (Read 12560 times)
Offline Nocage
« on: May 06, 2013, 02:05:35 PM »
Hello,
At 600 miles when my first oil change was due, I replaced the engine oil with Motul 5100 10W40. Now that I have 7,000 miles on the bike and am ready for the second oil change, I realized that in small print on the bottom left of the bottle it says synthetic blend. Did I just screw-up my bike?
I called several dealers and I'm not getting a consensus. Some say the Motul 5100 is a 50% synthetic and that I'll be okay and others say that I screwed up the seating of the rings and the bike will have problems. So, my questions are as follows please:
1. Did I harm the bike by using the partial synthetic for the last 7,000 miles?
2. Should I be worried about future problems?
3. At this point, should I continue to use the Motul 5100 or switch to conventional?
I would appreciate some input on this matter. I'm freaking out a bit...
2012 Concours 14
Bought new, now has 7k miles.
Frank
Offline wrichstrom
Re: Major Screwup? - Synthetic
« Reply #1 on: May 06, 2013, 02:14:38 PM »
I'm at work and don't have my manual by me, but my memory was the owner's manual said to change oil every 7500 miles (along with the 600 mile break in service).  Also my memory was that the 7500 mile oil change interval was irregardless of dino, synthetic, or blend.  I doubt you voided your warranty since you used a motorcycle oil.
I probably err on the side of caution and change my oil to frequently, but following the manual is probably just as good an approach to follow.
Enjoy your bike!  And keep riding and stop worrying.
2012 C-14
« Reply #2 on: May 06, 2013, 02:20:05 PM »
In my opinion the first oil change should have been done using conventional motor oil but I don't think that you've screwed anything up using the Motul. I'd just continue to use the same oil now.
Besides, what else is there to be done at this point?
Ride more worry less.
« Reply #3 on: May 06, 2013, 02:37:18 PM »
You haven't hurt anything!
« Reply #4 on: May 06, 2013, 02:38:29 PM »
  • No
  • No
  • Use whatever oil floats your boat...
« Reply #5 on: May 06, 2013, 02:41:10 PM »
  • No
  • No
except perhaps the exotic oils at the adult stores......    or at least if you use that insure the FOB has a fresh battery too  :finger_fing11:
« Reply #6 on: May 06, 2013, 02:55:47 PM »
FWIW I did my first oil change with full synthetic (Lucas 20W50) at 100 miles.  Why?  Has anyone ever seen what comes out at the first change??  I have, I used a coffee filter between the drain and the oil catch, really cool looking silver.  In my mind I didn't want any of that bonding somewhere it shouldn't.  Slim chance, but as this was my first brand spanking new motorcycle I decided to leave nothing to chance.  54,000 miles later she still runs as smooth as new and once I started using the K&N filter I never even get the start up rattle so many have.  So, when do I change the oil?  When the shifting starts feeling notchy.  May happen at 4,000, may happen at 7,000.
I'm fairly certain that few place as high a load on the motor for an extended amount of time as I do, yes, there are some, such as the sweet turbos out there and maybe another ZX14 TB modded bike, but other than that?  I get to play on the track 2-4 times a year so I get to really load her up, over and over.  Works for me, but as the saying goes, YMMV :)  No, I have nothing scientific to prove my findings, but I do have the SOTP dyno that validates it every time I ride ;D
« Reply #7 on: May 06, 2013, 03:00:18 PM »
Cactus?
« Reply #8 on: May 06, 2013, 03:08:04 PM »
Cactus?
Think ASL ;)  It's my way of being none PC ;D  Kinda slick, eh?
« Reply #9 on: May 06, 2013, 03:09:31 PM »
« Last Edit: May 07, 2013, 09:06:54 AM by Conrad »
« Reply #10 on: May 06, 2013, 03:10:59 PM »
So get out and ride it more
« Reply #11 on: May 06, 2013, 03:13:57 PM »
So many bikes, so little time ;D ;D ;D ;D  Quick spin to get an external drive today, still puts a smile on my face everytime I ride her 8)
« Reply #12 on: May 06, 2013, 03:17:06 PM »
ASL?  Don't know.  Trying to figure out what ASL means....   ;)
http://acronyms.thefreedictionary.com/ASL
« Reply #13 on: May 06, 2013, 03:35:05 PM »
YAOL!!!!
(Yet Another Oil Thread!!)
Has been posted a zillion times, but here it is again....  I do believe in synthetic oil has have a much longer life (double or longer).  I think it probably helps with engine wear but I don't think it is magic (I don't think it clings magically or is super-slippery and whatnot).
I do always use conventional oil in the first change, and follow the rev restrictions in the manual, then switch to 100% synthetic (such as Mobil 1) thereafter; and do this in all my vehicles (and for many, many years now).
Nothing you can do now, anyway.   I suggest using a 50% blend in this second oil change, THEN moving to synthetic.  Many of believe that modern engines are pretty much mostly pre-broken in at the factory and are not prone to "rings never seating properly" as might have been the case 20 or 30 years ago.
Offline katata1100
« Reply #14 on: May 06, 2013, 04:02:45 PM »
The big fear with synthetic (and I am not talking about group III wanna be "synthetics") is that the rings won't seat right during breakin. This is why Redline recommends not using their oil for the first 2000 miles.
If your oil consumption is low, your rings are seated, all is well in the C14 universe.
« Reply #15 on: May 06, 2013, 04:07:00 PM »
ASL-American Sign Language.  Cactus is, well, think slighly modified international peace symbol.  Pinky, ring, and index bent at second knuckle and the thumb protruding.  Online ASL sites don't "recognize" this but I'd be willing to bet Slivera will back me up ;)  My daughter did three years in HS with ASL, got to sign the National Anthem at a Mariners game and looked hard at becoming an ASL Interpretor but decided she wanted to learn to interogate instead so she joined the Army :o
« Reply #16 on: May 06, 2013, 04:08:26 PM »
For all, I have never, ever needed to add oil between oil changes.  But I have replaced my fob batteries once ;)
Offline Cuda
« Reply #17 on: May 06, 2013, 04:50:17 PM »
Red line says not to use Red line till 2,000 miles????
The people I know that use Red line rebuild their motors LONG before 2,000 miles
Race motors ;) I got a race in two weeks,  going to do a leak down test tomorrow , might have to re-ring,   I bet I have  less than ten hours  on it,  2.5L  Merc ... 2 cycle
We run the motors so close to the edge that the rings don't live very long .
We use to run Klotz R 50 now we  have to run AiSYN oil
The reason we have to run one oil or another is for Fuel Check that they do for the top five boats per class.
The Unlimited boys can run what ever they want and they swear by Red Line , they spray their motors No2.
MAX the Molecules are the same size so they don't  move , compress , squish out of the way
Gods waiting room Naples
2011 Atomic  Silver
« Reply #18 on: May 06, 2013, 04:52:25 PM »
Word of the day - Molecules
Offline Nocage
« Reply #19 on: May 06, 2013, 08:08:26 PM »
Thank you for all the responses. I feel much better. I didn't burn any oil, so as someone pointed out the rings should be sealed. Also, the owner's manual does state that a semi or full synthetic may be used, but it doesn't state a miles recommendation, so I assume even at the first oil change I could have gone to full synthetic? Basically, I don't think my warranty is void.
Again, thanks a lot. I nearly had a stroke. Now I'm going to go and make love to the road with my bike :)
Frank
