Author Topic: Rear axle question  (Read 9419 times)
Offline bigdogbites
Rear axle question
« on: May 01, 2013, 11:47:29 AM »
I just changed the tire on the rear and am trying to torque the axle nut to spec (approx 92 fp)
My question is --what keeps the rear axle from spinning ?
When I tighten the nut --I see the axle on the left rotating?
Am I missing something?
Re: Rear axle question
« Reply #1 on: May 01, 2013, 11:57:47 AM »
An Allen Socket (of the proper size) on a long ratchet or pull bar in the other end of the axle.  8)
How did you hold the axle to take the nut off in the first place?  ;D
Offline bigdogbites
« Reply #2 on: May 01, 2013, 02:42:32 PM »
nut comes off fine without holding the axle's other end--what size allen?
« Reply #3 on: May 01, 2013, 03:57:47 PM »
if you can't shove a few in the hole and figure it out - I'll go outside and do it brb
« Reply #4 on: May 01, 2013, 03:59:40 PM »
14mm
I use a ratchet style on the end of a small breaker bar
« Reply #5 on: May 01, 2013, 04:00:54 PM »
One more thing, i hate harbor freight tools but they had a whole set of big allen ratchets cheaper than sears had the "14" and mine has worked great since 2010
« Reply #6 on: May 01, 2013, 04:19:40 PM »
Can you take a picture while you're out there?  ;)
Offline bigdogbites
« Reply #7 on: May 01, 2013, 10:19:56 PM »
the wierd thing is --i can tighten the nut without holding the other side of the axle and the cotter pin lines up fine ?
Offline Barry
« Reply #8 on: May 02, 2013, 02:10:23 AM »
That's a little odd.  When you put the axle in, does it slide in with no force required?  Does the wheel spin freely?  You should need to hold the axle in place while tightening, at least initially until there is sufficient friction to keep everything in place.
Barry
Offline chap
« Reply #9 on: May 02, 2013, 09:54:54 AM »
I just did mine last week. The axle nut tightened without holding the other side. Torqued up and then tightened a little more to line up for the cotter pin. As per the Service manual.
2010 Concours ABS = Blue
2003 Concours - Red (sold)
« Reply #10 on: May 02, 2013, 04:15:51 PM »
Mine always comes loose without holding the axle but always requires holding the axle to torque past 80 ft/lbs
Offline CrashGordon
« Reply #11 on: May 02, 2013, 08:24:33 PM »
I've never had to hold the axle removing or replacing the nut. Done several tire changes and it's been the same every time.
Offline Cheesecake
« Reply #12 on: May 02, 2013, 08:59:20 PM »
Like a built in torque wrench? Nice. I never tighten mine past 80, that is plenty for axle bolts on this planet. If you ever try to change the wheel out on a long trip, it's not likely you will have a 3 foot breaker bar.
2008 C-14
« Reply #13 on: May 03, 2013, 04:10:28 AM »
Food for thought....
Offline koval68
« Reply #14 on: May 03, 2013, 04:41:43 AM »
Do you always bring a spare tire on longer trips? I don't ! Tire plug kit ,CAA, Green Buck and a credit card is all I need...if I can't fix a flat myself, bike gets towed to the nearest garage, where I'm sure they will have a breaker bar! ;) 8)
- Mahatma Gandhi
Offline chap
« Reply #15 on: May 03, 2013, 08:25:40 AM »
If it's anything like around here. The tires are all order. I usually have to wait 5 days for them to show up. Lots of time to break free that 94 ft lbs nut.
« Reply #16 on: May 04, 2013, 11:36:19 AM »
Actually I have a ratchet with a telescoping handle that I use for removing the axle.
