Author Topic: Murph Tip over bar info ++ more  (Read 1054 times)
Offline sgilbert14
« on: April 29, 2013, 02:36:25 PM »
I picked up a set of Tip Over bars this winter. I am looking for the directions to mount the fronts and what the spacer I  missing. I have 3 that came with it 15, 35' and 20 cm and have no clue as what the last one should be. Backs went on no problem but the front????
Also, pulled my rear shock to change the fluid and my cup was knocked so now I cannot measure out the right amount. Any have the volume needed to fill it back up? What is the best stuff to use? Thanks !
Offline Outback_Jon
Re: Murph Tip over bar info ++ more
« Reply #1 on: April 29, 2013, 04:53:59 PM »
It just so happens that I have a Tip-Over Bar service kit that I am about to install.  (After bending one of the bars last fall autumn.)
Offline sgilbert14
« Reply #2 on: April 30, 2013, 09:09:58 PM »
Thanks a ton. I now know that I am missing one of the 5/8" spacers and I could use a piece a SS pipe to make that.
