Author Topic: Question for 190/55/17 riders?  (Read 16797 times)
Re: Question for 190/55/17 riders?
« Reply #40 on: May 22, 2013, 07:39:40 PM »
Think I will stick with the 180, a bit cheaper and seriously doubt I would notice any real difference in better handling with a 190.
« Reply #41 on: May 23, 2013, 06:27:31 AM »
You'd have to get out of your subdivision and ride a little faster, methinks, dear Poke.
Offline kennqc
« Reply #42 on: May 29, 2013, 04:15:02 AM »
would it also affect the computer generated mpg
ken
It just occurred to me that a 55 rear tire would change the speedometer reading for the better I think. Our speedo's notoriously read fast. When my speedo shows 79 I am actually doing 75. With a taller rear tire the bike should be moving faster with the same drive shaft RPM. With a .42 increase in the radius I calculate about a 4% increase in speed at a given drive shaft RPM. Which should almost compensate for the speedo error. This is assuming the speedo works off the VSS on the drive shaft. Does it? Has anyone running 55's seen a more accurate speedometer?
« Reply #43 on: May 29, 2013, 08:36:55 AM »
You are welcome to try and follow me anytime sparky.  ;)
« Reply #44 on: May 29, 2013, 09:20:24 AM »
I would love to, you know that.
« Reply #45 on: May 29, 2013, 09:36:49 AM »
Quit working so darn much and get a move on!!!!  >:(
« Reply #46 on: May 29, 2013, 10:18:49 AM »
Well, retire already :)
« Reply #47 on: May 29, 2013, 11:12:54 AM »
Can't afford to at the moment....otherwise I would.
« Reply #48 on: May 29, 2013, 11:23:21 AM »
Become a Polygamist and marry Sophia Loren.  Problem solved ;D  I'd suggest Brittany Spears, but her money is managed :o
« Reply #49 on: May 30, 2013, 08:32:24 AM »
Why the hell I thought I had a 180 rear is beyond me.  ::)  So yeah I obviously didnt pay enough attention to what this thread even meant, so now I must figure out to go with the 50 or 55 now. I have a rear hugger too "carbon fiber" not sure what brand it is though, and have concerns about clearance like Jim did.
Edit: Just went out and checked, the side clearance will be fine, but there is no way the extra height would clear. I could try bending the bracket some, but just not sure it is worth it. I am leaving for Tenn/NC next Thursday, cannot have a screw up on tire size at this point.
« Reply #50 on: May 30, 2013, 10:38:45 AM »
My 55 is clearing my hugger, Poke, but it's a PR3....  Don't know if that has anything at all to do with anything.
« Reply #51 on: May 30, 2013, 12:13:34 PM »
Cant imagine that tire brand would matter much if any, I think that I need to bend my brackets just a tad bit further up and toward the cockpit. I went ahead and just got another 50, I know that works perfect.  :) [size=78%] [/size]
