from OP
I will not admit to any number though. Lets just say I was on 2nd, 3rd and at times on 4th gear
from
http://www.chp.ca.gov/programs/lanesplitguide.html2) It is not advisable to lane split when traffic flow is at 30 mph or faster
from me
2,3,4th gears are a bit faster than the
illegal advisable speeds.
OP
startled one driver who was trying to cut me off
CHP
•Other vehicles are not required to make space for motorcycles to lane split.
Me
From the original post I'm not convinced that the startled driver 'was trying to cut me off' is an accurate statement. If said driver was trying to cut the OP off, he wouldn't be startled by a horn.
If the driver was unaware of the OP it might have been due to OP's stated excessive speed. Also a startled driver is apt to react unpredictably causing an unsafe condition.
I'm not debating the good or bad of lanesplitting. I took exception to the OP's cavalier attitude to it, and to the effect such an attitude may have on the non riding public. Do you think the 'startled driver' with 'the look of terror' will be predisposed to give an inch the next encounter he has with a motorcycle. Not likely. So in this case the so-called individual choice has affected more than just an individual.
