Author Topic: Any Rosta's mounted on the left side?  (Read 5812 times)
Offline eng943
« on: April 11, 2013, 06:25:07 AM »
Curious if anyone that has installed a Rosta CC has mounted it on the left handlebar? Everything I have seen shows them on the right, which would work I suppose, but I think I would prefer it on the left.
Second Bike 2017 BMW R12R
Offline 1 wheel peel
Re: Any Rosta's mounted on the left side?
« Reply #1 on: April 11, 2013, 08:12:21 AM »
I mounted my control pad on the left with a bracket that I made.
« Last Edit: April 11, 2013, 09:51:36 PM by 1 wheel peel »
Offline basmntdweller
    • The Profile Brotherhood
« Reply #2 on: April 11, 2013, 08:21:41 AM »
Mine is also on the left with homemade bracket. Right side didn't make sense to me.
Pics this afternoon if I can remember.
Matt
'09 C14
'98 DR-350
'03 Honda CBR600RR track bike
« Reply #3 on: April 11, 2013, 08:46:58 AM »
Control on left side for me too with homemade bracket.
« Reply #4 on: April 11, 2013, 09:17:00 AM »
I mounted the control switch on the left.
I used Murph's aluminum bracket which is designed for the right side. I filed off the screw boss on the backside so I could attach it to my homemade bracket on the left. I've seen it mounted low on the left as well but I think my tank bag would have a problem with that. Mounted on top is more exposed to rain but easier to cover with a baggie and a rubber band. Murph's  switch covers are ugly but  cheap (3 for $10.25), even if you don't want it on your bike all the time I advise you keep one handy in the glovebox. My baggie was never there when I needed it. I think my glovebox was eating  them.  ;)
« Reply #5 on: April 11, 2013, 11:33:05 AM »
I first mounted it low. It was harder to operate with gloves on since with heavy gloves you cannot feel it and have to look. Up left like this turned out to be the best for me.
« Reply #6 on: April 11, 2013, 01:36:56 PM »
Mine, pretty much like the others less the orange buttons.
Matt
'09 C14
'98 DR-350
« Reply #7 on: April 11, 2013, 03:53:05 PM »
All the bikes I have seen with factory cruise control have the controls on the right side.  All the bikes I have owned with factory cruise control have the controls on the right side.
« Reply #8 on: April 11, 2013, 05:16:55 PM »
For some reason it just doesn't seem logical to me to have it on the right side.  But I have never thought about it all THAT much.
One thing that really makes me curious- what do you do with your right hand when cruise in engaged?  In a car, you take your foot off the pedal.  I don't know if I would always want my hand off the bar on a bike with cruise engaged.  But if you grab the grip, won't that interfere with the cruise?  Could it even cause damage?   That is a situation where electronic throttle control really is a great advantage, no?
Offline eng943
« Reply #9 on: April 11, 2013, 05:26:36 PM »
I take it than that the Rosta does not like moisture?
Offline eng943
« Reply #10 on: April 11, 2013, 05:29:48 PM »
Yeah, that was contrary to my experience with cruise on my past bikes as well. All were on the left, which is my preference for mounting the control on my c14
« Reply #11 on: April 11, 2013, 05:49:23 PM »
I have played a bit with mine. I can force the throttle down and it doesn't take a lot of force to overcome the servo. Opening the throttle is no different than when the cruise is off. Normal grip with cruise on doesn't really affect it. Your hand will move with it fairly naturally. My main reason for cruise is so that I can give my throttle hand a break for a few minutes.
Matt
'09 C14
'98 DR-350
Offline jayke
« Reply #12 on: April 11, 2013, 06:29:47 PM »
I've always had the cruise control key pad on the left.  It's easier to hold the throttle open with the right hand and set the cruise with the left for me.
When I have the cruise on,  my right hand is usually resting on the bar end.
« Reply #13 on: April 11, 2013, 07:04:09 PM »
« Reply #14 on: April 12, 2013, 12:27:13 AM »
The actuator is fine with it if the rubber dip switch cover is in place. The control switch on the other
hand was designed to be inside an automobile, so I assume that it isn't very water proof.
Mine has been exposed to heavy rain twice without a baggie, and it still works.
« Reply #15 on: April 12, 2013, 05:19:55 AM »
On the new thottle by wire bikes, you just rest your hand on the throttle as always.  it doesn't move under your hand.
On the old school bikes, as long as you are not using the cruise in the mountains, the throttle doesn't move more than a 1/4 inch or so and is barely perceptible.  I am always just resting my hands on the bars anyway.  I only grip the bars when it is cold and I have the heat on.
« Reply #16 on: April 12, 2013, 05:22:31 AM »
What factory cruise bikes did you have with the control on the left?
For me, on the right makes sense because that is where you control the speed of the bike.  You bump up or down the speed, hit resume, etc.  Of course the factory buttons are below the throttle so you can hit them with your thumb while holding the throttle steady.
« Reply #17 on: April 12, 2013, 08:17:27 AM »
Mine has been fine for 2 years. I got the control switch from Murph's and it's supposed to be water proof. My actuator is tucked up under the right upper faring. It can certainly get wet up there but is protected from much of the rain. Like someone else said be sure to replace the rubber seal on the dip switches on the actuator unit.
Offline jayke
« Reply #18 on: April 12, 2013, 09:49:32 AM »
The '13 Yamaha FJR cruise control switches on are the left.. that's why I bought one...well that and a few other things like time for a new bike.
Offline eng943
« Reply #19 on: April 13, 2013, 06:15:49 AM »
BMW RT,GT. Obviously either side can work, and according to the owner one side may seem more intuitive than the other.
