Author Topic: Won't start  (Read 7065 times)
Offline JDM
Re: Won't start
« Reply #20 on: April 19, 2014, 12:39:41 PM »
Finally had to bite the bullet and take it to the dealer who did diagnose the clutch switch as being bad as well as the contacts on the starter button needing to be cleaned. He did that work along with an oil change, coolant change and inspection for $243. I don't think that was too bad.  8)
Thanks for letting know what was causing it.  JD
Offline Daytona_Mike
Re: Won't start
« Reply #21 on: April 20, 2014, 06:28:23 AM »
I have never had a cleaning of the clutch switch  last very long. Same thing goes with the brake switch.
I just replace them. Very easy to diagnose those.  I also replaced the whole  kill switch assembly. They are cheap on ebay.
Re: Won't start
« Reply #22 on: April 20, 2014, 12:08:06 PM »
I have cleaned clutch and sidestand switches many times with major wd40 douching... always worked.
Sidestand usually has a sticky rod actuator, slip the red snooter tube under the rubber boot, or poke a hole in the boot to accomplish the same, and spray away..
Also diassembled ad scrubbed starter button wkith exceptional success.
$243 for that seems a bit high.... :P
Fyi, if you suspect a bad clutch switch, simply pull the wires, bend the tangs on a crimpon spade lug 90* to emulate a "plug" and use it as a jumper to connect the 2 poles in the harness socket. The circuit will then work all the time, you have defeated the switch.
