Author Topic: How often do people replace their air filter?  (Read 14023 times)
Offline katata1100
« on: April 04, 2013, 02:45:11 PM »
With most of my mileage being high speed touring, I wonder how dirty the filter is- original filter now at 14,717 miles.
Offline cablebandit
Re: How often do people replace their air filter?
« Reply #1 on: April 04, 2013, 02:49:24 PM »
This was mine at about 15,000 miles.  The sun is behind the filter.
Offline katata1100
« Reply #2 on: April 04, 2013, 02:54:15 PM »
Damn, that's filthy! How long did it take to replace it?
I have a '11 C14.
Offline tjpgi
« Reply #3 on: April 04, 2013, 03:14:03 PM »
Is that a dog or goat in the background or some other critter?
2011 GSXR 1000
2009 Concours ABS
1976 KZ900
1991 Sportster XLH 1200
« Reply #4 on: April 04, 2013, 03:39:07 PM »
I think that it's time man! How long it takes depends on how often you've had your plastic off. If you're comfotable taking it off then it won't take long. If you've never had it off before, well, it might take a bit of time. It's a nice afternoon project. Have you changed your coolant? It would be a good time for that while you have the plastic off.
« Last Edit: April 05, 2013, 04:22:23 AM by Conrad »
Offline kjk concours
« Reply #5 on: April 04, 2013, 03:45:03 PM »
Replaced mine, pretty dirty at 12,300. I live in the north east  and the roads still are a little dirty for the long winter.
Offline cablebandit
« Reply #6 on: April 05, 2013, 07:10:27 AM »
About 10 minutes taking my time.  No need to remove the side plastics to remove it.  Just remove the black piece on top and remove a bracket and it slides right out.
Offline jdhreiss
« Reply #7 on: April 05, 2013, 09:03:00 AM »
  I went to the K&N at 10k miles on my 08 and clean it every other oil change (10k).  It usually looks like Cable Bandit's at that point.  I also do much high speed touring, year round, in the Pacific Northwest.  Desert - mountains  - rain!
Joe R.
2008
106,000 miles
Joe Reiss
SW Washington
Offline katata1100
« Reply #8 on: April 05, 2013, 10:15:37 AM »
What black piece are you talking about?
« Reply #9 on: April 05, 2013, 11:32:33 AM »
Mine are still good at 25K   :D   :D   :D
This filter was at the top of the Rockies, offroading in Arizona desert, Vegas, offroading in Moab, Utah, chasing Brisket in TX, blistering OK, and all over the blue ridge mountains
Southeast USA, and a few days in Key West, FL.
« Reply #10 on: April 05, 2013, 11:42:39 AM »
Wow! What were you doing while the filter was off galavanting around the counrty?
Offline cablebandit
« Reply #11 on: April 05, 2013, 12:34:53 PM »
To the left of the gas tank as you look down from above.  You have to remove the plastic tank cover to take it off so I guess technically you'll remove two pieces.
Offline katata1100
« Reply #12 on: April 05, 2013, 01:09:55 PM »
S
You got me fixated on "chasing Brisket in TX...". I usually chase after microbrew on my C14, you just gave me something different to think about!
I live in N.NV, one of the windiest, dustiest places in the U.S., I am not optimistic about the condition of my filter at 13717 miles, but we'll see...
Offline olie
« Reply #13 on: April 05, 2013, 01:20:30 PM »
is your bike a MY 08-09 or MY 10+ ?? :o
13 Blue Connie, 8/4/2013
16 Green Versys 1k
11 Red Vette
Offline cablebandit
« Reply #14 on: April 05, 2013, 02:06:01 PM »
2010
Offline C1xRider
« Reply #15 on: April 07, 2013, 02:07:29 PM »
If you want to know how to change it yourself, you could always look in the Wiki section ...
Specifically : http://www.zggtr.org/index.php?topic=2844.0
Offline luther163
« Reply #16 on: April 12, 2013, 01:17:32 AM »
I replace air filter every 10000 km.
Offline katata1100
« Reply #17 on: April 12, 2013, 11:35:33 AM »
I replaced mine yesterday, I think I did it slightly different from other methods on my '11 bike.
1) Remove the three allen bolts that hold that plastic cover on the tank.
2) Remove the allen bolts holding side fairing. You don't need to remove it, just loosen the bolts and pull fairing away so you can get your hand through under the frame to yank out filter.
3) Remove three bolts that hold black trim and glove box.
4) Remove two bolts that hold filter aluminum strip
5) pull out relays out of foam thingy that is next to tank.
6) relay bracket, just remove one bolt and push the thing to the front of bike as you pull out filter.
I have never done this before, took me about 25 minutes. No need to mess with the position of the shield, no pop rivits to remove.
Bike idles better, feels smoother and more powerful. My theory is that if you have a four cylinder car, the C14 filter probably will last 25%-50% as long as the filter in that car. I say that because the engines are sort of close in size, but the C14 is inky dinky compared to what is in my cars, looks more like a filter for a large lawnmower than a bike, with small pleats and small overall size. The thing was pretty dark, no flies or strange bugs smacked in it, but just black looking. On my last trip last month, my mileage was down from I usually get, even in eco mode and I bet it will be better now with a clean filter. The dealer wanted $43 for the thing, next time, I'll either try to source aftermarket paper or even consider cotton gauze (no K&N vs paper arguments, please).
« Reply #18 on: April 12, 2013, 03:05:52 PM »
Did mine once at about 22,000. Put a K&N in it. I now have about 34,000 miles and will probably clean the K&N in the next few weeks.
Offline booger
« Reply #19 on: April 12, 2013, 03:19:31 PM »
Best brisket in Texas comes from the smoker in my back yard. ;)
