Ok, I figured out how they go. I do have another problem that started me on the process of messing with the cables. The throttle moves smoothly, but if pulled to full throttle it locks. To get it to unlock you have to push the grip forward very hard. I noticed that the bracket that the cables attach to on the carb had rotated forward and when the throttle gets pulled all the way the bracket binds with throttle assembly. I pushed it back with a screwdriver, but it still wants to rotate forward. Has anyone had this problem? If so, how do you tighten down that bracket to keep it from moving?
