Author Topic: 17" Front Wheel Conversion for '94 thru '06  (Read 11055 times)
Offline GF-in-CA
« on: June 01, 2011, 10:00:17 PM »
While many C10 owners are interested in taking advantage of the latest tire technology, the dwindling selection of high performance tires available in sizes to fit the C10’s 18” front wheel has made this increasingly difficult. Manufacturers heavily favor 17” front wheels on sport and sport touring motorcycles, evidenced by the fact that at the time of the writing of this article, only one new sport touring motorcycle was offered with an 18” front tire. The rest of the current sport and sport touring motorcycles are equipped with a 17” front tire. A cursory look at tire availability during the writing of this article indicated that there were nearly twice the amount of front tires offered in the 120/70-17 size alone than the total number of 18” tires that will work on the C10. These and other factors have led to a desire by some owners to convert to a 17” front wheel. Fortunately for 1994-2006 C10 owners there is a bolt-on option for converting to a 17” front wheel, using the wheel from another Kawasaki model.
Here’s what you’ll need for the conversion:
-   Tools for removal/ replacement of the front wheel, including removal and replacement of the front brake rotors, and removal/ replacement of the front wheel bearings, if required.
-   A front wheel from one of the following:
Kawasaki ZR750 C1-C3 (1990-1993)
Kawasaki ZR7/ ZR7S F2/ H1-H5 (2000-2005)
Kawasaki ZX6 D1-D4 (1990-1993)
Kawasaki GPZ1100/ZX1100E (1995-1997)
-   Front axle spacers for your model wheel.  Most used wheels still have the wheel bearings installed, and therefore will include the spacer between the wheel bearings, as will a new wheel.  The right hand (brake lever side) spacer for the ZR7 F and H is Kawasaki part number 92152-1160, while the other models all have the same part number, which is 92143-1335.
-   The speedometer gear drive from a Kawasaki ZX6D.  The speedometer drives from the other donors will fit, but will introduce more speedometer error than the ZX6D speedo drive.  The Kawasaki part number for the ZX6D drive gear is 41078-1070.
-   New wheel bearings, if you plan on replacing them, Kawasaki part number 601B6203UU.
-   Your choice of tire in the 120/70-17 size.
Here are the steps for the conversion:
-   Remove and replace the bearings in the conversion wheel, if necessary
-   Mount the new tire
-   Remove the stock front wheel
-   Remove the brake rotors from the stock front wheel
-   Install the brake rotors on the conversion wheel
-   Install the conversion wheel, using the stock front axle, the spacers and speedometer drive acquired for the conversion.
-   Go for a ride!
Yes, it really is that easy, though you may find that you want a 17” rear wheel to go along with the front, if you haven’t already done so, but that’s for another article.  Steering will be slightly quicker, due to the lighter wheel  and reduced steering angle resulting from the smaller diameter tire.
Here are a couple of pictures of what the installation will look like with the stock fender:
Gary F.
1998 C10
California North State
Offline SlowSam
  • 1987 C-10 sans plastic
Re: 17" Front Wheel Conversion for '94 thru '06
« Reply #1 on: December 12, 2011, 08:05:15 PM »
Hello ~
I own an '87 C-10 and have found the following 17" front rim.
1997 Kawasaki ZX600R front wheel rim straight OEM.
To the best of your knowledge, will this work as far as converting?
I appreciate your time and candor.
Cheers!
Farkles: Fork Brace.  Braided steel lines.  Upgraded brakes; springs & pads.  Motor rebuilt by 4 & 6 Racing; flouroscoped/blueprinted 2000.  Looking to do more in the very near future.
« Reply #2 on: December 12, 2011, 09:38:23 PM »
If you are still running an 87 front end no this will not work.... Notice this mad is for the 94 through 06 bikes... There is a differance in the size of axle and bearings here as well as brake rotor size in both OD and width between the forks....
Offline mrwog
  • Be well and safe
« Reply #3 on: August 31, 2012, 04:57:14 PM »
Just curious if anyone knows.
How does the bike ride with the 17" front and using the stock rear? Does this (17 with stock rear) make the bike much lower giving up ground clearance for cornering or one should do both 17's.
Paul
some people are like Slinky's good for nothing but still fun when tossed down stairs
« Reply #4 on: September 06, 2012, 04:49:54 PM »
Paul
There is only 1.0" difference (or less) in height of the 120/70-17 compared to the 120/70-18 to which you divide this in half to get the loss in ride height which is negligible.
I run the 170/60-17 which is roughly 10 mm shorter than the stock 150/80-16 in the rear with a 120/70-17 in the front and I'm a heavy man and I'm not having ANY cornering or bottoming issues...
Myself I'd not bother with just doing the front as the gain is just not worth the hassle; you would be better off with a 110/80-18 front tire in place of the 120/70-18... The 110/80-18 really is a better fit on the rim. (Trust Me!) Do the rear before you do the front. (Trust Me!)
