Author Topic: TPS  (Read 7190 times)
Offline wingrider
TPS
« on: March 10, 2013, 09:16:09 PM »
Is it possible to completely eliminate the factory tire pressure monitoring system on an 09. I have an aftermarket system from my wing that is a lot nicer than seeing  a low battery warning anytime the temps drop below 50.
Re: TPS
« Reply #1 on: March 10, 2013, 09:27:29 PM »
Solder in new batteries,  have dealer replace the sensors, let the batteries go dead and say the heck with them, or pull out the sensors and install regular old valve stems. The system will just display 2 simple lines where the pressures should be, no warnings or red lights to worry about.
Offline koval68
Re: TPS
« Reply #2 on: March 10, 2013, 09:31:02 PM »
Anything is possible my friend, but ECU will have to be modified. Sounds like a job for Don from Guhl Motors! Maybe you can kill two birds at once, get your ECU re-flashed and that annoying TPS warning removed!
http://www.guhlmotors.com/Index.html
- Mahatma Gandhi
Re: TPS
« Reply #3 on: March 11, 2013, 08:51:08 AM »
My understanding is if the batteries go totally dead then you will not see the warning any longer.
Re: TPS
« Reply #4 on: March 11, 2013, 10:25:39 AM »
I felt the same way until I got a flat on the C14. The system warned me way before I felt it.
Re: TPS
« Reply #5 on: March 11, 2013, 10:40:58 AM »
That is correct.  :)
Re: TPS
« Reply #6 on: March 11, 2013, 11:16:50 AM »
DESTROY the batteries, as they are evil  ;D
Offline Jim M.
  • 2008 C-14
Re: TPS
« Reply #7 on: March 11, 2013, 12:08:08 PM »
I was thinking of getting rid of them on my '08 until this morning. On the way to work, I notice the red indicator. Yep, a low rear pressure warning. Looks like I picked up a nail. I was traveling in a straight line and didn't realize any difference in handling til the warning came up- there was only 23 lbs in there!  :o
Re: TPS
« Reply #8 on: March 11, 2013, 12:10:05 PM »
+1 Same thing happened to me.
Re: TPS
« Reply #9 on: March 11, 2013, 04:37:21 PM »
Yet we have all been getting along just fine without them, since the introduction of motorcycles.  ;)
Re: TPS
« Reply #10 on: March 11, 2013, 05:12:14 PM »
True. We have also been getting along without gas gauges, heated grips, gear indicator, clock, electric windshield and about 100 of the 155 hp. But I don't want to give up any of that either ;D
Offline pistole
Re: TPS
« Reply #11 on: March 11, 2013, 06:40:12 PM »
- amen to that !
Re: TPS
« Reply #12 on: March 11, 2013, 06:41:06 PM »
 :goodpost: :chugbeer:
Offline wingrider
Re: TPS
« Reply #13 on: March 11, 2013, 08:19:21 PM »
I don't plan on going without anything. I have a Doran system from my wing I will put on the bike. I have run a TPS system for five years and like the sense of security they give.
Offline MGvaleri
  • Country: it
Re: TPS
« Reply #14 on: March 27, 2013, 09:02:32 AM »
68 months sensors batteries to replace.
is time to change the batteries, the battery warning sensor exhaust is going on too many times.
http://youtu.be/KLs3w6gZL6I
Mgvalerio. 8)
Re: TPS
« Reply #15 on: March 27, 2013, 12:40:34 PM »
Rhino for president!!!  :o   ;D
Offline texrider
Re: TPS
« Reply #16 on: March 28, 2013, 02:14:56 PM »
Just got around to changing the TPM sensor batteries on my '09 for the first time. Once apart, I saw no reason to solder, cut, or weld anything to do with it. I simply pried the tabs off the old battery, slipped the new one in between the tabs, then re-assembled the sensor. The case is meant to hold a battery tight, whether it has welded tabs or not. Works perfect-o, and the next battery will be a breeze.  8)
2014 Valkyrie
Offline MGvaleri
  • Country: it
Re: TPS
« Reply #17 on: March 28, 2013, 02:23:17 PM »
You've done so much simplicity photo! Thank you.
MGvalerio. ::)
Re: TPS
« Reply #18 on: April 04, 2013, 08:36:13 AM »
Were the tabs soldered to the batt? You pried the tabs loose with what? I will be doing this next tire. change and wondering what is safer, a soldering iron or a pry bar.
Re: TPS
« Reply #19 on: April 04, 2013, 08:45:49 AM »
Without any solder or weld it's just a matter of time before the pressed connection oxidizes and you get the low battery warning.
