Author Topic: Knob key won't come out...well, it finally did!  (Read 20572 times)
Re: Knob key won't come out
« Reply #20 on: March 05, 2013, 06:10:58 PM »
Just because it was designed and intended to be removed, doesn't necessarily mean it is a good idea.
Offline pistole
« Reply #21 on: March 05, 2013, 08:27:04 PM »
- this was discussed a while back.
- simple solution : leave knob in place. Cut a spare key for the bags and fuel cap. Easy.
Offline udoggie
« Reply #22 on: March 05, 2013, 10:13:46 PM »
+100
I paid $4 each for two keys (for the blanks and to have them cut) from a local locksmith, and it's worth every penny.
I leave the knob key alone, and keep one of the spares in my sleeve pocket on my aerostitch for the gas cap and/or saddle bags.
Jeff
Aloha, OR.
« Reply #23 on: March 06, 2013, 04:53:26 AM »
I've used the stove knob for everything, every time, and never had a problem.
Of course I spray some lock lube in the keyholes from time to time.
Not skeered. ;D
« Reply #24 on: March 06, 2013, 05:16:16 AM »
Me too. Lot easier than digging for the fob. A little DrySlide lube works wonders.
« Reply #25 on: March 06, 2013, 09:00:09 AM »
Oh, I always push down- you have to or it is simply impossible to turn.  But it is STILL difficult to turn and to insert and remove the key.  And there is a bunch of white stuff.  The bike is only 2 years old and it started getting this way maybe 6 months after I got it.  Kind of a mystery.
You should take that lock apart Max and get that corrosion cleaned out of there.
Offline lemosley01
« Reply #26 on: March 06, 2013, 10:23:20 AM »
Keys on caps open my bags so they stay in there.
Can you expand on this? What do you mean? One of the aggravations - because I am in and out of my sidebags everytime I ride - is being forced to get the key out each time. My Royal Star could be locked or you could leave them unlocked and push the lock in to open the bags.
« Reply #27 on: March 06, 2013, 10:28:28 AM »
Some folks have bought extra keys and then glued color matched caps onto them for use in the bags, they mostly just leave the keys in the bags for convenience.
See this thread for more info.
http://www.zggtr.org/index.php?topic=3602.0
« Reply #28 on: March 06, 2013, 10:35:04 AM »
I carry my spare key on my 'janitor' retractable key ring.....
« Reply #29 on: March 06, 2013, 10:40:47 AM »
That's what I do.
« Reply #30 on: March 06, 2013, 11:11:06 AM »
Very nice Jim, when you get done playing with your keys there's a clean up needed on aisle 4.
« Reply #31 on: March 06, 2013, 11:56:19 AM »
Offline booger
« Reply #32 on: March 06, 2013, 06:11:30 PM »
I dry lubed the heck out of mine, several times, to no avail.
And then I discovered it was bent. ;)
Offline clogan
« Reply #33 on: March 08, 2013, 06:40:19 PM »
If I ever get my knob key out, I'll check it for bends, and lube it up real good...but honestly, I can't see it ever coming loose at this point. I mean, that rascal is REALLY stuck. So, I guess I'll just forever leave it in the switch, and buy me some spares on which to epoxy some caps. Then leave 'em in the bags and seat locks.
I also have two cars with fob systems, but they both also require keys. Fobs are an unnecessary complication, IMHO. Guess they said the same thing about keys when ignition keys were first introduced way back when.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
« Reply #34 on: March 09, 2013, 10:03:39 AM »
Before I got my extra keys and used the stove knob, I found it difficult to get a good grip on it. So using a Dremel I cut horizontal lines on the sides to give it a better grip.
« Reply #35 on: March 09, 2013, 10:21:12 AM »
With my Infiniti, I never touch a key or mess with the fob.  It is just in my jacket.  When I get close the car, I can open the doors or trunk with my hand and start the car with a finger.  THAT is what I would want on the Concours :)   (Open bags, seat, gas tank, and start, all without a metal, insert-it-type key)
« Reply #36 on: March 09, 2013, 02:38:04 PM »
+1...
Mama's new Camry is just like that too, very slick.  8)
« Reply #37 on: March 09, 2013, 03:18:04 PM »
I've had that on my Prius since late 2004.  It spoils you.
« Reply #38 on: March 09, 2013, 03:49:36 PM »
Yep, as others have said, the key is most likely bent and was forced into the lock. Now it is stuck and will be difficult to remove although it will come out. You will probably need a pair of large pliers or medium vice grips to grab onto the key knob and pull it out (wrap the key knob in a rag first to reduce the chance of gouging the key knob). Once out, straighten the key and it will again slide in and out (easy boys!) of the ign. lock.
I have been using the main stove knob key on my bike in all the locks on the bike since '07 but perhaps disaster is just around the corner. I think it will be OK if I continue to chant the incantation before starting the bike though. Dat dare KiPass can be an evil system- at least that is what I've heard now and then....
Starting yesterday, my knob key will not come out of the switch. It otherwise works fine, turning easily from lock, on, fss, etc., but I can't remove it when in FSS. It's like the knob key is "locked" in place, and cannot be removed. Thus, when I stop for fuel, I now have to fumble around and find my fob, remove the hidey key, buy my gas, then reverse the process.
A simple work around is to buy a separate key for fuel, seat and saddlebags, but I hesitate to do that until I asked advice from other Connie owners.
All thoughts appreciated.
Offline booger
« Reply #39 on: March 09, 2013, 06:27:27 PM »
I just put a pair of vice grips on mine and jerked it out.
