Author Topic: How to remove your oil filter video...without a filter wrench!  (Read 209171 times)
Offline Mugsy19
Re: How to remove your oil filter video...without a wrench!
« Reply #20 on: February 23, 2013, 11:00:31 AM »
Great idea. Thank you for sharing.
« Reply #21 on: February 23, 2013, 11:50:14 AM »
NICE!
motocopter
« Reply #22 on: February 26, 2013, 11:45:28 AM »
Crazy how tight they put them on. I had to hammer a screwdriver though the filter to get enough leverage to get it loose.
Ditto. Did the same for the first oil and filter change on the 2K8Z1K.    8)
Offline Necron99
    • Facebook Page
« Reply #24 on: February 26, 2013, 12:35:25 PM »
Good video.  I use my kung fu grip.  :)
-Dylan Thomas
2010 ZG1400 COG #9384
Offline Metal
« Reply #25 on: February 26, 2013, 01:57:15 PM »
When I've had an overtightened oil filter and/or the absence of a wrench, I've always resorted to a method that a motorcycle mechanic showed me once. Get a medium sized phillips screwdriver with a fairly sharp point and with a few taps of a hammer, puncture thru one side of the oil filter to the other side (obviously, make sure you have a pan underneath). Once it's through, just a good tug on the screwdriver handle (as if it were a handle on an old sailing ship wheel) will typically rotate the oil filter loose. You can hand-loosen it once it's free.
Offline reesedp
  • Sail Army
« Reply #26 on: February 26, 2013, 05:34:07 PM »
Prior to the Army, I did lube-n-tune for five years, and serviced thousands of vehicles.  It never ceased to amaze me how many time I had to use the pliers, cups, and claws.  I would say that the vast majority of the hundreds of different sizes and brands of filters had "Tighten to contact plus a half 1/2 turn" right on the side of the filter or the box it came in.   I have not had to use a wrench on one of mine since I was a teenager.  I have never had one loosen or leak either although failing to ensure the gasket came off with the old filter got me a couple of times back then.  It'll hold for a few seconds...
« Reply #27 on: February 27, 2013, 04:39:30 AM »
I had one like that, in which the old gasket didn't come off with the old filter. Started her up and oil sprayed everywhere. It's become a habit now to check that as soon as I spin off the old filter.
« Reply #28 on: February 27, 2013, 07:44:27 AM »
I have never needed a tool. I have a bionic grip. My thumb was shattered in a crash and the doctor rebuilt it stronger than before.
Offline reesedp
  • Sail Army
« Reply #29 on: February 28, 2013, 06:55:27 PM »
Better and faster too?  Cost roughly $6,000,000 in 1980 dollars?
« Reply #30 on: March 01, 2013, 08:23:11 AM »
It's been what, 30 years since that show? But I can still hear the theme music in my head and the noise they use when he is lifting a tractor or something.
Offline BeaverMatt
« Reply #31 on: March 01, 2013, 09:00:32 AM »
The title says "without a wrench".  I see a wrench being used.   :o
Beaver Matt
2009 C14
Black
« Reply #32 on: March 01, 2013, 04:21:55 PM »
Let's not get hung up on titles and what's contained therein... ;)   Threads morph...
« Reply #33 on: March 04, 2013, 10:43:26 PM »
Not faster, just stronger. And not pretty. But it only cost about $6000 in 1986.
