Author Topic: A cruiser very effective and simple at the cost of a dollar.  (Read 3115 times)
Offline MGvaleri
  • Country: it
« on: January 23, 2013, 03:55:21 AM »
This my system may be equipped with release means of the lever of the hand brake. ;)
Visible in 20 minutes.
http://youtu.be/2_rfVsZwawo
MGvalerio. 8)
Offline works4me
Re: A cruiser very effective and simple at the cost of a dollar.
« Reply #1 on: January 23, 2013, 05:25:44 PM »
Nice. Reminds me of the thumb screws used by H-D.
Simple yet effective.
Offline julianop
« Reply #2 on: February 13, 2013, 12:33:06 AM »
I wouldn't feel comfortable with anything that doesn't have a quick release - preferably activated by the brake lever.
Backing up a little further, I drive Wisconsin and Minnesota, and a simple throttle lock like that just doesn't seem to work for me; I'm either speeding or dragging.
Julian.
Elk River, MN.
Seasonal Temporal Navigational Disorder - that inexplicable but wholly satisfying affliction that causes one to lose the ability to drive a motorcycle straight home after work in the summer months, despite the apparent ability to make the reverse journey that same morning.
Offline MGvaleri
  • Country: it
« Reply #3 on: February 13, 2013, 01:36:10 AM »
Offline Two Skies
  • Road? What road?!?
« Reply #4 on: February 13, 2013, 12:25:50 PM »
A cheap trick that I stumbled upon ties in with my crampbuster.
The crampbuster comes with a rubber band sleeve thingie that helps the crampbuster grip and stay more or less in place.  It does slowly vibrate downward under pressure, so every few miles I do need to bump it back up into position.  No big thing.
Anyways, I've found that if you overlap the rubber sleeve over the bar end just slightly, this will hold the throttle in place for a small amount of time, so if you need to flex your fingers or whatever it'll keep you at speed for a few seconds.  It doesn't require much force at all to twist the throttle to overcome the overlap, as the band tension is very easy to break (the vibes through the bars will allow the throttle to come to rest given enough time, say a minute or so).  This could be a temporary problem if the bike went down for some reason, but at that point you'll have much more important things to worry about besides the engine revving... (broken bones, not getting run over by the person behind you, etc.).
Also, several here are a big fan of the cat (caterpillar) O ring as a budget cruise control.  Forum search is your friend.
