Author Topic: Looking for ideas on how to secure my C14 in a U-Haul  (Read 1782 times)
Offline eng943
« on: January 16, 2013, 09:17:26 PM »
Moving back to Chicago next month and will be loading my C14 into a 16ft U-Haul. I have not transported a bike before, and so far have thought to put the bike on the center stand and tun several cam lock straps to various points inthe truck.
Anyone come up with any bulletproof ways to secure a bike in a truck?
Second Bike 2017 BMW R12R
Re: Looking for ideas on how to secure my C14 in a U-Haul
« Reply #1 on: January 16, 2013, 10:39:39 PM »
Not a Concours, but similar with many great suggestions.
http://www.bmwlt.com/forums/showthread.php?t=11858
Offline thundermax
« Reply #3 on: January 17, 2013, 03:54:21 PM »
ON my 6 x 12 trailer with a wood floor, I nailed two 2x4s parallel in the front running lengthwise the trailer. They are 12-16 inches long. Wide enough apart so tire goes inbetween them. Same going up and down at front on top of the end of the flat two. Then I roll the bike in the slot on the floor and into the slot at the front wall. Strap through triple tree carefully and tighten within 12 inches on each side of the wheel. Push down front end some compressing front shocks and tighten straps. Strap back wheel down with strap actually at 2 o'clock on the tire and ends secured forward a little, say past the axle about 2-3 feet each side of bike. This puts pressure for bike to stay in place forward. You can strap the handlebars on each side to a wider place on the floor, snug and not tight. They will just balance the bike. You should be good to go. You may need to buy some hardware for straps to hook to. hardware screwed to the floor very securely. Good luck.
Riding 46 years. In order, 1958 Cushman 721 Highlander, 1960 Cushman Super Eagle, 1971 Honda SL 100, 1974 Yamaha RD 350, 1975 Honda 750 Four, 1971 Honda SL 175, 1998 Yamaha Vmax, 2005 Yamaha Vmax, 2009 Kawasaki Concours 1400, 2012 Kawasaki Concours Arabian Red.
Offline eng943
« Reply #4 on: January 17, 2013, 05:51:35 PM »
Thank you to all. Very helpful!
