Author Topic: Setting a bead %$##@@!!!  (Read 5507 times)
Offline c1obrien
Re: Setting a bead %$##@@!!!
« Reply #20 on: January 01, 2013, 06:25:58 PM »
Finally, success.
Today I removed the rear tire to replace the battery in the TPS, a delicate operation but not too technical. Putting the tire on the rim went pretty well. Took the core out of the 90-degree valves and blow in about 80 psi. The bead set right up, POP, POP and I backed off on the air ASAP. Then I filled it to 42 psi. Maybe I'm learning a thing or two thanks to you guys. There's something really great about learning to work on your own bike.
chip
Offline Shoe
« Reply #21 on: January 01, 2013, 09:23:39 PM »
It feels good afterward, plus you learned something. Time for a beer.
Eat corn. Drill for oil.
2008 Concours, 2010 Goldwing
