Author Topic: Fuel Starvation when tank 1 bar or lower  (Read 11217 times)
Offline tjhess74
Re: Fuel Starvation when tank 1 bar or lower
« Reply #20 on: July 27, 2016, 04:14:08 PM »
I had this problem as well and replacing the fuel filter did not cure it.  I found the actual fuel pump motor on ebay for $25 and replaced it. She's run just fine ever since!
I tore apart the old motor (which was NOT easy) and saw quite a bit of wear inside.  I run my tank from full to nearly empty each week, so I wonder if the extra heat from a mostly empty tank took a toll on the motor? I dunno, but it's cheap enough to fix every 7 years if that's the case because I'm not stopping to get gas every other day.
The 'other' forum evicted me!
« Reply #21 on: July 29, 2016, 07:33:19 AM »
Running a vehicle to near empty with an internal fuel pump is not a good idea.
« Reply #22 on: July 29, 2016, 07:35:58 AM »
The whole idea of putting an electrical device in an explosive container is a bit out there.....
That's what they do in the desert...
« Reply #23 on: July 29, 2016, 07:37:26 AM »
My best friend (a master mechanic) has told me that over and over, for many years.  The theory being that heavy contaminates would sink and collect at the very bottom, accumulating over time.  Often I wondered if it would make sense to somehow vacuum out or flush out the fuel tank every several years.... something much more possible/practical on a motorcycle compared to a car.
« Reply #24 on: July 29, 2016, 07:43:11 AM »
Indeed.  I remember many years ago when I first learned about the practice of the pump being INSIDE the tank with the gasoline and it certainly sounds insane.  Gasoline is not flammable in its liquid state- it must be a vapor (and then it is VERY VERY flammable).  But there are vapors in that tank too!
The engineers must know what they are doing, though, since it is very rare you see/hear about a gas tank explosion/meltdown.  It does happen, but most of the time it is not the actual tank or pump- it is a leak, allowing fuel to escape, vaporize, and touch something very hot.  [Cue the videos of people causing their bikes to burst in flames by filling them improperly, and often while it is running!]
Offline tjhess74
« Reply #25 on: July 30, 2016, 02:49:15 PM »
Not running your tank low has nothing to do with contaminants.  The pickup is from near the bottom anyway, plus filling up the tank will stir up any debris that is in the tank, thus allowing it to enter to fuel pump assembly.  Regardless, that is what the filter is for.  No one should have much debris in their tanks if you're using decent gasoline and keeping your fuel cap closed.
What Virginia Jim was referring to was the extra wear on the pump motor by being run on a low tank.  While I'm no scientist, the pump doesn't shed heat as well in a small volume of fuel as it does in a higher volume.  That adds strain to the motor via some magical principles of thermal transfer.  While I'm aware of this, it's still not enough to keep me from doing so.  I'll stop for gas every four days on my commutes, not every other day.  Just ain't happnin'. $25 for a new pump motor and an hours worth of my time to replace it every 7 years is worth it for me to not have to stop for gas so often. It's got a 5.8 gallon tank, and I use almost every ounce of it regularly.
« Reply #26 on: July 30, 2016, 03:13:16 PM »
You're right.  It's not that bad to replace...unlike a car or truck.
