Author Topic: How many was that?? Rear wheel bearing failure.  (Read 109688 times)
Re: How many was that?? Rear wheel bearing failure.
« Reply #80 on: December 11, 2012, 09:10:15 AM »
Thanks
Offline MGvaleri
  • Country: it
« Reply #81 on: December 11, 2012, 10:28:54 AM »
Was this the original Kawasaki bearing? How many miles on the bike?
I km percorsi col C14 non fanno testo a questa mia informazione di prevenzione,il mio cuscinetto non si è rotto per i km percorsi ma per mancanza di sfere 4 al suo interno...capito.
http://www.youtube.com/embed/8dHoxsnvdcs
MGvalerio. 8)
« Reply #82 on: December 11, 2012, 10:43:20 AM »
So the question is: will Kawasaki help you out with the cost of fixing the bike?
Offline MGvaleri
  • Country: it
« Reply #83 on: December 11, 2012, 11:03:57 AM »
Kawasaki sa tutto    :MUTA FU: (Dialetto Siciliano)
Kawasaki knows All: DUMB FU: (Sicilian dialect
MGvalerio    :cannon:         Kawasaki.
« Last Edit: December 11, 2012, 12:08:29 PM by MGvaleri »
« Reply #84 on: December 11, 2012, 11:31:19 AM »
I'm thinking not based on MG's reply..
Offline MGvaleri
  • Country: it
« Reply #85 on: December 11, 2012, 02:30:26 PM »
From the Forum English I have pointed out that even the broken bearing in seven balls as the other, beautiful oversight that I had, now I do not understand how you can break the cages that hold the ball being broken bearing well lubricated.
MGvalerio. :o
« Reply #86 on: December 11, 2012, 02:39:42 PM »
It's possible it was bad from the factory, I guess.   If it had broke within the warranty period you would have had it covered.  Now, not so much unfortunately.  You could push it higher up and possibly retain a lawyer but I think it would be less to fix it assuming someone of your skills.
Offline MGvaleri
  • Country: it
« Reply #87 on: December 11, 2012, 02:44:38 PM »
Con 430 euro Jim  ;D risolvo,in più la concessionaria mi farà un prezzo di favore per i ricambi.
MGvalerio. 8)
Offline blue14
« Reply #88 on: December 12, 2012, 05:29:11 PM »
Probably Chineese bearings....
2010 C14, 2007 ZX14,  2004 KTM 300SXC
Offline pistole
« Reply #89 on: December 12, 2012, 07:49:56 PM »
- imho , its impossible for the bearing to come with missing balls.
- its more likely that the bearing failed in use : pitting of the races and then destroying the balls.
« Reply #90 on: December 13, 2012, 12:09:38 AM »
Ask yourself this.  What would happen if the axle nut was loose, lets say the spacer got hung up during assembly somehow, the nut felt tight, but once moving it freed itself.  What will that new gap create?  I really do believe this was an assembly error, we all make em.  Bottom line is for whatever reason MG survived to ride another day.
Offline MGvaleri
  • Country: it
« Reply #91 on: December 13, 2012, 02:17:36 AM »
Son of Pappy :)
 well as removing it the nut you can not create a fusion of the genre, this can happen to change the alignment of the stem with bearing failure. ;)
MGvalerio. 8)
Offline MGvaleri
  • Country: it
« Reply #92 on: December 13, 2012, 09:02:45 AM »
Prevention is better than cure!
Maintenance of bearings in the parade.
http://youtu.be/i93aDn5_8J4
MGvalerio. 8)
Offline Cold Streak
« Reply #93 on: December 13, 2012, 09:27:33 AM »
I agree with Pistole.  It's nearly impossible for the bearing to be supplied with missing balls and if had been, you would have known it long before the mileage you accumulated.  Usually bearings fail by overheating and eating the ball cage.  Once that happens, the balls can disintegrate or pop out of the bearing.  The process for assembling a ball bearing is to put all the balls in, then put the ball cage/spacer around them.  Your missing balls are probably laying alongside the road someplace or in your wife's purse like most married guys.  I got mine back as part of the divorce agreement, but I digress...
« Reply #94 on: December 13, 2012, 10:33:02 AM »
Humor time.  ZG, take note, this is a black bike :stirpot:
« Reply #95 on: December 13, 2012, 12:26:34 PM »
 :o
Offline McJunkie
« Reply #96 on: December 14, 2012, 05:20:32 AM »
After watching that video, that would explain some things
Offline MGvaleri
  • Country: it
« Reply #97 on: December 14, 2012, 07:02:47 AM »
This my fat pad of C14 which is broken does not know what it is.
http://youtu.be/ulfbLivNcJU
Thanks Kawasaki.
MGvalerio. 8)
Offline tbanzer
« Reply #98 on: December 15, 2012, 09:15:54 PM »
I dont see anytrhing happening if axle was loose. The bearings would just be free to move slightly on the shaft. Either a quality isue withe bearing at time of manufacture, contamination introduced during its use, or overheated lubricant.
Offline McJunkie
« Reply #99 on: December 16, 2012, 03:53:39 AM »
I agree with what someone said previously about not torquing the rear axle correctly causing it to spin. Don't need much elongation of the hole to over stress the bearing.
