On a related note, for those of us that have the inside corners of the nose fairing coming occasionally in contact with the front of the tank (due to spills or whatever), I recommend sticking these to the front of your tank, where the inner corners of the front fairing & rubber fairing sleeve (kitty corner with the fairing pockets) are able to come in contact with the tank:
http://www.homedepot.com/h_d1/N-5yc1v/R-202514360/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=furniture+pad&storeId=10051#.UK6Qc64eZRoI've also adhered these between the sidebag antler pads and the contact patch (one on each), on both sides (so 4 pads total), which helps the sidebags stand a little more upright, and provides a little more cushion for those bumps in the road.
With the 8 pack, you end up with 2 spares, should one or two fall off at some point, or you can share with a friend...
Also, Bergman's quick release tank kit is da bomb, but I digress...
