Author Topic: Helibars Horizons! My new favorite farkle!  (Read 14993 times)
« on: November 11, 2012, 10:06:05 AM »
Pricy I know but for anyone like me looking for a luxury touring bike with high end sport like performance a C14 with helibars is the best accessory you can add. Very well engineered and well made. The adjustability allows you to dial in the perfect comfort. After going through 4 different seats I now wish I had started with helibars then pick an aftermarket seat. It's been many decades since you could buy a car without having an adjustable seat. All high end bikes should have adjustable bars IMHO.
« Last Edit: March 08, 2015, 09:49:41 AM by maxtog »
Offline PH14
Re: Helibars Horizons! My new favorite farkle!
« Reply #1 on: November 11, 2012, 10:18:20 AM »
All bike used to have adjustable bars. Many still do, but not as adjustable as the Helibars.
Offline Armyguns
« Reply #2 on: November 13, 2012, 05:00:09 AM »
Could not agree more.  Had the Horizons installed by Helibars at Laconia this year and I absolutely love them.
2010 C14 ABS
Offline FIX UR CRITTER
« Reply #3 on: March 07, 2015, 01:42:56 PM »
Hi All,
Quick history so you know where i am coming from.. Riding for 35 years, had about 30 bikes, including last model FJR. The c14 is the best bike I have owned, though of course it is not perfect. I have never had one of those.
 I am generally cheap and try to do any modification myself before spending too much. well once i decided i will not find a better bike for under 25k - i decided to throw down some $$ to upgrade the c14 to make it perfect for me...
 I tried many seats before going with a $600 russell.. problem solved.. well worth the money.
 Next were the handle bar height and angle.. tried risers and they helped- but not perfect.. next went big with $700 heli handlebar replacements. problem solved - not only do they eliminate (with manic salamander heavy bar end weights) any and all vibe in throttle  - but they have so many possible adjustments and so easy to adjust - i can now ride all day and night with little to no discomfort. Link is below - the only negative is i wish they hand like a ball adjustment so grip angle could be adjusted in any angle.
 The other item was the biggest wind screen i could find- which was the 7 jarock.. it is not for everyone though because it is huge- but my wife and i can speak through our communication device at 90+mph with little effort. also no buffeting. I am completely happy with my connie now.. if it was about an inch shorter and 100 lbs lighter it would be perfect.. but some of that is my average stature.. 5'10, 29" inseam, 185lbs. I love my connie for short trips and for cross country.... i think for the $$ it can't be beat.. will be at the gap week of April 20th. would love to hook up with someone
https://www.helibars.com/product/kawasaki-c14-multi-adjustable-handlebar-replacement-system
« Last Edit: March 07, 2015, 02:32:42 PM by FIX UR CRITTER »
Prevent a litter, Fix ur Critter
PLEASE neuter all your pets.. there are millions of starving strays that wish you did.
'08 C-14, '08 Bandit 1250
'08 SV650, '07 YZ250F
« Reply #4 on: March 08, 2015, 07:47:16 AM »
So, to make the bike perfect for you, you changed a SPORT touring bike into a sporty TOURING bike.  I think I would have just bought a wing and removed the trunk.  :o
Just messing with you  ;D
Personally, I am more comfortable leaned forward, so my perfect setup is stock handlebars, lower windscreen, and firmer seat that sits me a tad higher than stock.
« Reply #5 on: March 08, 2015, 09:53:24 AM »
Glad you got the bike the way you wanted it :)  Sometimes spending some money is the easiest way to transform something from good into great, especially since no two people are the same.  The Helibars Horizons are very impressive and something I would have probably gone for, if they were available before I spent the time and money on regular Helibars risers and Phil's wedges.
« Reply #6 on: March 08, 2015, 10:12:57 AM »
<snip>
I've not heard of this shield. Must be huge if it's bigger than the v-stream sail.
« Reply #8 on: March 09, 2015, 07:28:56 AM »
Exactly! Still 200 lbs lighter than a wing and way more power. 900 miles days and can still thrash it in the twisties.
« Reply #9 on: March 12, 2015, 11:28:22 AM »
The Voyager XII had adjustable bars.  You could move them back and forth and there was also a pivot near the grips where you could adjust them out and in.  Took a lot of adjusting to find that sweet spot for me.
Going to rallies, it was interesting to see how the different riders set up the bars.  Everything from a dirt bike posture, to a 60s chopper bars coming almost straight back at you.
« Reply #10 on: March 12, 2015, 01:36:17 PM »
Imagine a car that had a fixed seat, not even forward and back, and a fixed steering wheel. That's what most bikes a like. I think higher end bikes should be adjustable from the factory.
Offline mikeb2411
« Reply #11 on: March 13, 2015, 10:09:40 AM »
You should try the Aeroflow...bigger than the VStream. Moves a bit more in the wind but it blocks much more wind than the VStream does...at least for me and my riding position. I'm 6'1" and ride tall so there was much more buffeting with the VStream (I know it's off-topic but had to throw my 2 cents in)
Mike
Ojai, CA
2016 Black Triumph Trophy SE
Offline Doenitz
« Reply #12 on: March 21, 2015, 08:00:15 PM »
I have the V Stream and bar risers, but found the buffeting much reduced when I went to a Schuberth helmet.
I would suggest that the first farkle would be to change the stock tires to PR3 or 4's.  The Bridgestones lasted 3,500 KM ( about 2,200 miles).
Offline mikeb2411
« Reply #13 on: March 22, 2015, 05:15:06 PM »
I'm switching to the California Scientific XL Windscreen...should be here tomorrow! Agreed on the tires! I went to the PR4 GT's and love them! I'm on my second set now.
Mike
Ojai, CA
Offline mikeeitup
« Reply #14 on: March 22, 2015, 05:54:14 PM »
I want them really bad. I feel like I need them to experience the bike fully but I cannot bring myself to spend over 20% of my bikes worth on handlebars!
Mike
~Mike~
~2012 Black Connie~
Offline Deziner
  • Phoenix
« Reply #15 on: March 22, 2015, 06:55:58 PM »
Mike
If they make your bike 30% more comfortable,  they're a bargain. I spent nearly $500 on tires that will wear out in a season, Helibars will last as long as you have your bike. Longer if you mount them on your next Concours.    ;)
Offline mikeeitup
« Reply #16 on: March 22, 2015, 07:32:57 PM »
Stahp it with your much better reasoning! I'll have to wait 'til my next return.
Mike
~Mike~
~2012 Black Connie~
Offline Deziner
  • Phoenix
« Reply #17 on: March 22, 2015, 07:46:26 PM »
Mike
It's not better reasoning, it's called JUSTIFICATION.  I've gotten very good at it over the years. With my lack of common sense I need a motorcycle that will go 150+ like I need a box of hair ties. (I'm nearly bald.)  I bought the Concours because it was water cooled and had hard bags. Yeah, right....
« Reply #18 on: March 22, 2015, 08:38:05 PM »
Mike
i felt the same way as you - and dragged my feet for a long time. now i only wish i would have done it sooner. I figure, not only does it add dramatically to my enjoyment of the bike - i can add them to my next connie - or sell them on e-bay when done.. call them and ask if they have a money back guarantee if you don't love em...
« Reply #19 on: March 23, 2015, 09:19:04 AM »
+1 When I bought the bike I knew before I got it home I needed tall, further back bars for long distance. I did risers, then designed and fabricated my own pull back risers. And finally bit the bullet and spent the $700. Made this bike all day comfortable for me.
