Author Topic: zrx 1100 calipers  (Read 1708 times)
Offline Irish GTR
zrx 1100 calipers
« on: October 31, 2012, 02:19:36 PM »
greetings,
Has anybody fitted these with adaptor plates to post 95 front rotors...
Re: zrx 1100 calipers
« Reply #1 on: October 31, 2012, 02:54:04 PM »
If I recall correctly forum member ZRX Mopar used to make brackets to adapt the 6 piston calipers for use with the 300 mm rotors but I also seem to recall a fit issue with the pads hanging off the rotor slightly which required a little grinding of pad material to not cause problems down the road. While I use 6 piston calipers on my ZRX front end know that these calipers are more problematic than 4 piston calipers. Need to be keep clean for proper action.
Offline Irish GTR
« Reply #2 on: November 01, 2012, 10:56:57 AM »
Thanks,
That makes sense,
