I just installed Murph's wiring harness for main lamp, and I am planning on wiring the aux lights with the provided lead(s). OK, here is the dilema. I would like the option to have the aux lights on with both the high and low beam main. I can just run both high and low aux leads into the relay, but I am wondering if there is going to be a flicker/momentary off when I use the switch?
I guess what I am asking, is anyone running a similar setup, or did you omit high beam aux lights (which I think is the legal way of doing it).
I have aux lights on my cruiser, but I just wired them through a switch that is independent of the headlight high/low switch.
