Goes great on a 2010 as well....no loss of torque or power here either.
Sweet, thanks guys! As soon as I get a feew more $ saved up, I'm going to pull the trigger.
My mind is never completely set until I hit the submit button, but I've used V&H pipes on 2-3 bikes in years past and have been happy with sound and workmanship. I've also used TBR pipes with very good results. There have been a few that haven't been all that good as well.What do you have in mind?
Ok...I ordered a PC-V from Fuel Moto loaded with the appropriate map, and a Holeshot 17" Comp 2 in Stainless. Should be here in a few days.
Nice choice in exhaust.......but you don't need the PCV, install without and see how it runs first "trust me". You only need a power commander if you go full system or pull out the flies, my bike runs flawless with my Area P and no PCV.
My 'flies have been removed and I have a K&N filter as well. I shortened my stock pipe 6", that combined with everything else, it runs a bit lean as it is. I figured it would be worse with a freer flowing pipe.
