« Reply #6 on: October 06, 2012, 05:41:37 AM »
Sounds like a new battery is in your future soon.
Lead acid batteries will TYPICALLY last about 3 to 5 years. However, if you use it a lot (which it sounds like you do) you can cut the life a lot. And if you have ever let the battery die (run down to nothing or almost nothing) that will also greatly lower the life.
Logged
