Author Topic: Do You Remove the STOVE KNOB key?  (Read 48983 times)
Offline bob14
  • go forth and meet the shadowy future without fear
Re: Do You Remove the STOVE PIPE key
« Reply #20 on: May 12, 2011, 12:31:59 PM »
Never take it out man !!! she likes it in
2008 C14
COG 8211
AMA 848986
Some people try to turn back their odometers. Not me, I want people to know "why" I look this way. I've traveled a long way and some of the roads weren't paved.
Offline blue14
« Reply #21 on: May 12, 2011, 12:48:23 PM »
There it is... :rotflmao:
2010 C14, 2007 ZX14,  2004 KTM 300SXC
Offline Texas Concours14
« Reply #22 on: May 12, 2011, 01:19:49 PM »
It is made out of soft metal, and bends easily.  Based on experience and having to straighten the key a couple of times, now I never remove it.  Made extra keys to open luggage and gas cap.
2010 C14 ABS
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #23 on: May 12, 2011, 01:42:57 PM »
Took mine out once to see it.  In the same instance I locked the forks to see how to do it and haven't done either thing since.
T.S.R.
Offline dbird29
« Reply #24 on: May 12, 2011, 03:23:03 PM »
Is there another fork lock besides the lock position on the ignition switch?
2010 C14 Blue
2003 Buell XB9S
1982 GPz 750
Offline CrashGordon
« Reply #25 on: May 12, 2011, 04:16:57 PM »
I leave the key in.  I do lock the forks when I'm parked anywhere but my garage.  I don't think anyone has tried to mess with it.
Offline Vault13Hero
« Reply #26 on: May 12, 2011, 04:25:50 PM »
Yes, only when I need to use it for the tank at fuel stops and once in awhile for the bags.  Fork locks?  Maybe twice since new.
Ditto for me.
Black 2009 ABS
« Reply #27 on: May 12, 2011, 04:47:38 PM »
Wouldn't that be +3?
Thank you for keeping the math correct.  You are now our resident arithmetician and astrologer astronomer.
Bob
« Reply #28 on: May 12, 2011, 05:38:47 PM »
As already said, the stove knob key is designed to be left in the  bike. The only reason to remove it is to add fuel, open a pannier or remove the seat! The ignition switch has nothing to protect it from dirt and moister out of the switch other than the plastic cap of the stove knob key. So IMO it should never be removed other than for a short duration pertaining to the bike. I never used the stove knob key. I had spare keys on soft fobs made for this use.
 I would lock the forks at night or in unfamiliar area's when the bike may be out of site for more than a short time frame.
« Reply #29 on: May 12, 2011, 06:13:53 PM »
No, only the fork lock position of the main ignition switch. To the best of my knowledge, there is only one way to lock forks on each motorcycle, whether that method is the ignition or a separate lock on the frame.
« Reply #30 on: May 12, 2011, 06:16:30 PM »
To no one in particular, I always remove the ignition key to open the fuel cap ('gashole'), saddlebags or to unlock the seat, and find that the most convenient way to use the bike. I never use the fob key and I have not had any additional keys made. The ignition key is starting to show a bit of wear but has not bent yet (I am a bit disappointed in that, it sounds more exciting than what my key has done.... nothing).
Offline rider47
« Reply #31 on: May 12, 2011, 06:24:57 PM »
I haven't removed it.  I use the small key in the FOB.
Offline DaveO
« Reply #32 on: May 12, 2011, 07:50:28 PM »
i leave stove key thing in the bike and fob in glove box .
Offline JRT
« Reply #33 on: May 12, 2011, 07:57:00 PM »
Yes
Yes
No
In fact I can't even get the down key out of the bike without a pair of pliers. I just can't grip it enough.
I do want to get some new keys made as I lost the credit card style that comes with the 2011.
2011 C14 ABS Ebony
V&H CS-1
Dispatch 1
« Reply #34 on: May 12, 2011, 08:36:27 PM »
i haven't ever removed mine in 32,000 miles.
Offline Pynikal
« Reply #35 on: May 12, 2011, 08:56:23 PM »
i only take the key out when messing with the bags.   its always in there and locked.
Offline Cheesecake
« Reply #36 on: May 12, 2011, 09:13:30 PM »
Yes you must remove it and never leave it on the bike. Anyone with a pair of vice grips can force the key to start the bike and steal it.
2008 C-14
Offline riverbound51
  • It's all about the ride.
« Reply #37 on: May 12, 2011, 09:41:57 PM »
I don't even remove it to fill the tank and unlock the bags.  I use the fob key.
2008 Concours 14
Always looking for the road less traveled
www.odysseymotorcycletouring.com
« Reply #38 on: May 12, 2011, 09:56:08 PM »
It can be removed?
« Reply #39 on: May 13, 2011, 04:22:35 AM »
No it can't.  The bike won't start without a fob.  The stove top portion is designed to 'slip' around the key.  Forcing the top clockwise accomplishes nothing.  Not sure if you were serious with that answer or not.
