Author Topic: Do You Remove the STOVE KNOB key?  (Read 48914 times)
Offline Rembrant
Re: Do You Remove the STOVE PIPE key
« Reply #120 on: March 18, 2015, 05:31:19 PM »
Maybe it's just me but if I push down on the gas hole cap ever so slightly, the ignition key turns effortlessly with no fear of catastrophic failure.
Haha...I was just going to say the same thing...you guys ARE giving the filler cap a little push down, right? Mine turns like butter, always has...my current 2010 C14, and the 08 before it.
Must be the salt air in your neck of the woods.
Don't think so...I'm at sea level, right next to the ocean...and it doesn't cause any problems for me.
Actually, I didn't even know there were problems with the fuel filler lock until I read this...
They've always worked fine on both my C14's, and the bikes before them as well.
Rem
« Reply #121 on: March 18, 2015, 05:43:14 PM »
The salt is different up North than in the Mid-Atlantic.  Everyone knows that.
Offline Rembrant
« Reply #122 on: March 18, 2015, 05:53:12 PM »
Haha...is this a Geico Commercial?...lol.
« Reply #123 on: March 18, 2015, 06:02:32 PM »
It just might be.  Their HQ is just west of me.
Offline Rembrant
« Reply #124 on: March 18, 2015, 06:06:23 PM »
See, I knew it.
Seriously...I've never had an issue with the fuel filler locks, but...I don't notice a lot of things that others do...so what I don't notice doesn't really matter...lol.
Rem
« Reply #125 on: March 18, 2015, 06:20:28 PM »
There are some bikes that got a sort of whitish crud around the cap.  Don't really know why.  Mine has never got it and I haven't had a problem with using my spare key on it.
« Reply #126 on: March 18, 2015, 06:21:34 PM »
Mine doesn't.  Must be the salt air in your neck of the woods.
I posted about it in another thread somewhere.  Mine gets this white stuff on it somehow.  Could be the area, who knows.
To others- yes, I always push down while turning.
Offline PH14
« Reply #127 on: March 18, 2015, 06:27:13 PM »
Good point, I will lube the petrol cap,  but I do think the key is made from softer material. The keys from the fob do feel stiffer ( easy boys)........ to use Brian's phrase ;)
Yes, I believe you are correct, the stove key does seem to be softer.
« Reply #128 on: March 18, 2015, 07:25:42 PM »
Vindicated!  :banana :banana
« Reply #129 on: March 18, 2015, 08:11:57 PM »
What'd you do, have the dummy bite down on both keys and see which key had the deeper impressions?
Offline XR6
  • Country: nz
  • 2009 ABS Black
« Reply #130 on: March 18, 2015, 09:43:23 PM »
I do agree that it is important to push down with the key (or put pressure on the petrol cap opposite to the hinge ) before turning. There seems to be some back pressure from the rubber seal.
The key is soft, it bent easy and straightend easy.
2009 ABS Black, AreaP carbon, K&N air filter, PC V, Flies Out.
« Reply #131 on: March 19, 2015, 08:42:12 AM »
Maybe it needs a little blue pill.  ;D
Offline Deziner
  • Phoenix
« Reply #132 on: March 19, 2015, 08:45:53 AM »
Or Cialis,  that way it gets hard when you want it to.  :rotflmao:
Offline PH14
« Reply #133 on: March 19, 2015, 04:34:28 PM »
Nah, I know it was soft, it's been soaking in Pamolive.
Offline PH14
« Reply #134 on: March 19, 2015, 04:35:50 PM »
For those times you want to spend time in a bathtub on a beach with your motorcycle.
« Reply #135 on: March 19, 2015, 05:20:42 PM »
And who does not?
By the way, I just glanced at the title of this thread and read it as 'stove knob key'.... but it really says 'stove pipe key'. Hmmmm, what is a stove pipe key? Who thinks the key in the ign. of a C-14 looks like a stove pipe?
« Reply #136 on: March 19, 2015, 05:21:41 PM »
Hey, something new to soak my fob in! I ran out of ideas for things to dip that thing into years ago- thanks!
« Reply #137 on: March 19, 2015, 05:32:19 PM »
Good point.  I don't even know what a "stove pipe" is, unless that is the chimney/exhaust from a wood burning stove or something?  Certainly doesn't look like a pipe.  Certainly doesn't look like just a stove.  Attached is a photo of the knobs on my stove (really old stove).  Yep, looks like that!  I am changing the name of the thread to match (although all the existing posting subjects will, unfortunately, still say "stove pipe").
« Reply #138 on: March 19, 2015, 05:37:36 PM »
I know I don't want MY motorcycle anywhere near a beach.  The few times I encountered sand near the beach while riding a motorcycle were VERY scary.  And to keep it on topic- sand is probably not a good thing for the ignition key, anyway :)
Offline PH14
« Reply #139 on: March 19, 2015, 08:46:48 PM »
