Author Topic: Vavle adjustment help  (Read 7464 times)
Offline sgilbert14
Re: Vavle adjustment help
« Reply #20 on: October 04, 2012, 06:51:32 PM »
Just order the gaskets! 6 days downtime but better then what could have been!
Re: Valve adjustment help
« Reply #21 on: October 04, 2012, 07:36:35 PM »
Good... Cause we really do have your best interest in mind. While Silicone does indeed have its place it is the last and least used sealant in my arsenal and I work on many types of marine equipment on a daily basis; right now I'm staring at 52 cylinders worth of diesel engines and that's just the back half....
While the covers you removed don't normally even need to be removed thus many people will cement them on to prevent leaks; leaks that likely would not even appear if the surfaces are cleaned properly. Be sure to remove all trace of old gasket and what I like to do is use a simple spray adhesive such as made by 3M lightly on one side of the gasket and the removable part. That's right neatly glue the gasket to the cover and then lightly OIL the gasket when you put it back on the engine this way when and if you need to remove it later you just might do it without any damage whatsoever.
Offline midnightrider
« Reply #22 on: October 04, 2012, 09:33:40 PM »
Well, I guess I'm a terrible connie owner, because I have been using gray RTV sealant on the side cover since the first valve adjust. However, I always make sure both surfaces are clean and oil free. And I use it very sparingly. I have very little squeze out, if any at all. Been working fine for 76,000 miles. Just sayin silicone is fine when used properly. ;D
2004 C10 RIP
« Reply #23 on: October 04, 2012, 09:46:14 PM »
Yes the key word here is "sparingly"
Offline sgilbert14
« Reply #24 on: October 05, 2012, 04:06:11 AM »
I have used it for a few years pn my old bike but the idea of a clog oil port is enough to ge the gaskets. Now seeing that I have a few days before they get here I am thinking of checking the oil screen as well. Never did this before so I hope it is not too much of a pain?
« Reply #25 on: October 05, 2012, 04:17:23 AM »
No harder than it is to drop about a baker's dozen 6 mm bolts; but in order to drop the oil pan you need to drop the exhaust header and in order to drop the header you need to drop...... Well you get the picture. In dropping the pan you will also be looking at another gasket as well as some o-rings that need to checked/watched are in the correct position in the pan to motor interface. If you've been neat with the silicone as another poster has stated I'd still sleep at night but if you've been sloppy with the stuff and had a lot of squeeze out when using the stuff then you've had a lot of squeeze "in" and that could be worrisome.
Offline sgilbert14
« Reply #26 on: October 05, 2012, 04:31:43 AM »
Still have the gasket on the way and I think I will keep the screen for the spring pre ride list. How I used the silicone is I clean both surfaces and then add a layer to the cover only. I get it as uniformed and smooth as I can and then let this dry overnight. Befreo I install trhe cover I check and clean anything that could break off and clean off all edges with the razoe blade. After this I have a solid layer on the cover and I can install it with anything oozing out or into anything. Used this on my 750 for 3 years without issue but just the idea of an issue scared me enough to get the gaskets.
Offline Summit670
« Reply #27 on: October 05, 2012, 07:49:25 AM »
I've used Permatex Ultra Blue on my side cover for 75,000 miles and 22 years.  Sparingly.
What I've done is apply the silicone, lightly seat all the bolts.  Let sit overnight.  Tighten the bolts the next day.
In the future though, with the added knowledge on how to re-use gaskets, I'll do that.  At least you can tighten the bolts right away and be done with no need to allow time for the sealant to cure.
Arctic Cat M8 163 rules
Offline RFH87_Connie
« Reply #28 on: October 05, 2012, 09:01:50 AM »
... because I have been using gray RTV sealant on the side cover ...
Gray RTV?  Are you sure you aren't using Yamabond or Hondabond?  These are actually butyl rubber and not Silicone.  Those are what I use to replace any gasket that doesn't require a "special" gasket.  Wipe a little on both surfaces, then assemble a few minutes later and be done.  It to can get into passages but you have a little more control on its application.
Do not let this send you on a wild goose chase, but....
If your tap is still there after all of this, I have something you could look at that SISF wants me to look at on my motor after a conversation with him.  I got a motor of unknown origin to replace the one that blew back in June from a bad crank bearing #3.  The valves are set correct, and I have since added a manual CCT.  I still have a tap that is coming from the top end, seemingly near piston 1.  Short of piston slap or a wrist pin being bad (and I think the sound would come from a lower point and would go bad fast), mine is perhaps a rocker arm that is worn on the pad that rides on the cam lobe.  The only way to check this is to pull the camshafts out.  Next time I open it will be to inspect the lobes as it might tell we which one it is (if this is the problem).  Otherwise it is a new engine for me.  Right now it is just an "around town" bike and the sound hasn't changed, so i'm just waiting for the cold weather to give me a reason.  At a minimum, since the valve cover is already off, get a bright light and a magnifying glass to inspect the lobes close up.
Hopefully it is just your valves.  You never need to take the ign cover off if you do the starter bump method.  It is extremely simple.
« Reply #29 on: October 05, 2012, 09:32:31 AM »
That in a nutshell is the correct way to use silicone if your going to use silicone.
Offline gtr1000
Re: Vavle adjustment Need help
« Reply #30 on: October 05, 2012, 10:06:37 AM »
. Pulled it all apart again, pulled the plugs, left the valve cover off and turned it over and it was quite as ever. Lightly put the plugs in, no cover, and the noise is back. So that rules out hitting the valve cover but what else should I go after?
What's the part # of the plugs you're using? NGK ????? or whatever.
Plugs out, no noise, plugs in = noise.
Paul OTP (near Windsor, GB).
06 C-10, 2009 to .....
A5 C-10, 2000 to 2009.
Offline sgilbert14
Re: Valve adjustment help is now generator chain tensioner needed !
« Reply #31 on: October 05, 2012, 12:39:46 PM »
WOW !!!!!!!!!!!!!!!!!!!!!!! The bike was to the paint of turning it over again and the noise was worse. This time I did the hose in the ear and slowly went through each part of the motor. Why does every sound seem to come from the top of the engine? Turns out what I was hearing is the generator chain tensioner. The guide is broke on the top and along the inside edge and the noise that I have been hearing is the F*&^*& thing bouncing off the clutch housing. So, now I have to replace the tensioner but at least the clutch housing is market but ok. Bad thing is that I have been going after ghost for 3 days. Good thing isthat it could have been really bad if this went out someplace on the back roads that I like to ride.
Now does anyone know where I can buy the part?????? Doesn't look like you have any options but to buy the whole thing.
Offline SteveJ.
« Reply #32 on: October 05, 2012, 07:07:23 PM »
Congrats on the relatively less painful diagnosis.
Any parts house/dealer can order it up.
My local dealer matches Ron Ayers pricing, so I can get the better price and still support the local dealer.
America's Seaplane City
Offline sgilbert14
« Reply #33 on: October 06, 2012, 09:16:41 AM »
I took the bike a 2nd slow going after by checking out wear areas around the tensioner found that it was pushed back as far as the bolts would allow. Now the slide on the top is still worn and the inner edge is gone, but by moving the thing forward as far as possible and lock tighten the bolts I have cleared up the slap against the clutch and the noise is gone. My gasket set should be here in a few days and I will see how things hold up then. Any ideas on this fix would be great and this is one area that I have not touched on the bike so I don't know if it has been played with or not.
