Author Topic: Fuse breakout from 2008 - 2012  (Read 8688 times)
« on: October 01, 2012, 10:04:31 AM »
2008 - 2009 taken from Source Post: Post http://www.zggtr.org/index.php?topic=8002.msg96716#msg96716
Kawaski Concours Years 2008 - 2009
Fuse box 1 (midway)
1 - KIPASS Signal Relay - 10A
2 - Oxygen Sensor Heater - 15A
3 - KIPASS - 10A
4 - Electric Windshield - 30A
5 - Accessory - 10A
Fuse box 2 (towards the back of the bike)
1 - Fan - 15A
2 - ECU - 15A
3 - ABS Motor Relay - 30A
4 - ABS Solenoid Valve Relay - 20A
5 - ABS ECU - 10A
6 - Ignition - 10A
Fuse box 3 (towards front of bike)
1 - Turn Signal Relay - 10A
2 - Headlight - 10A
3 - Taillight - 10A
4 - Horn - 10A
5 - Headlight (HI) - 15A
6 - Headlight (LO) - 15A
Relay Box
1 - Fan
2 - Headlight
3 - Main
4 - Fuel Pump
5 - Starter Circuit
Kawasaki Concours Years 2010-2012
(SOURCE: schematic in back of Kawasaki Service Manual) Part No. 99924.1431-03
For K-ACT ABS Equipped Models
Relay Box
1 - Fan Relay
2 - Headlight Circuit Relay
3 - Unused
4 - Fuel Pump Relay
5 - Starter Circuit Relay
Fuse box 1 (towards front of bike)
1 - Turn Signal Relay Fuse - 10A
2 - Headlight Relay Fuse - 10A
3 - Taillight Fuse - 10A
4 - Horn Fuse - 10A
5 - Headlight Fuse (HI) - 15A
6 - Headlight Fuse (LO) - 15A
1 - Fan Fuse - 15A
2 - ECU Fuse - 15A
3 - K-ACT ABS Motor Relay Fuse - 30A
4 - K-ACT ABS Solenoid Valve Relay Fuse - 20A
5 - Ignition Fuse - 15A
Fuse box 3 (midway)
1 - KIPASS Signal Relay Fuse - 10A
2 - Oil Control Solenoid Valve Fuse - 15A
3 - KIPASS Fuse - 10A
4 - Electric Windshield Fuse - 30A
5 - Accessory Fuse -  5A
6 - Grip Warmer Fuse - 10A
Differrence from above found with NON K-ACT ABS Equipped Models
was fuse box 2
1 - Fan Fuse  - 15A
2 - ECU Fuse - 15A
3 - Ignition Fuse - 15A
Sources:
http://www.zggtr.org/index.php?topic=7892.msg133810#msg133810
