I've had problems with my carbs for a while now, and I want to get them resolved. I know I could just send them to SiSF, but that would be admitting defeat -- not in my nature.
I swapped my originals with a spare set when my jets -- start, pilot, and mains -- all became plugged with a crusty crystal growth. I think it was a byproduct of JB Weld and alcohol.
Mains and pilots are easy -- just use new -- but the start jets are a different story, since they are pressed into the bodies. Does anyone know what the diameter of the start jets are? With a combination of carb cleaner and a .008 wire, I can get them to open again, but I'd like to be closer to the actual size.
Second question, associated: there is what appears to be an air bleed on the same tower as the start jet -- is that indeed what it is?
